What Power Is Needed To Accelerate An Object To 2.7 rad/s In 5.2 s?
The discussion focuses on calculating the power required to accelerate an object to an angular speed of 2.7 rad/s in 5.2 seconds. The correct formula to use is P = KE/t, where KE is the rotational kinetic energy. The final answer for the power needed is established as 1.3 W. Participants emphasized the importance of correctly determining the rotational kinetic energy at the specified angular velocity.
  • Understanding of rotational dynamics
  • Familiarity with the concept of kinetic energy
  • Knowledge of angular velocity and acceleration
  • Ability to apply the power formula P = W/t
  • Research the calculation of rotational kinetic energy using the formula KE = 0.5 * I * ω²
  • Learn about the relationship between torque and angular acceleration
  • Study the principles of angular motion and its equations
  • Explore the application of power in rotational systems
This discussion is beneficial for physics students, mechanical engineers, and anyone involved in dynamics and rotational motion calculations.
n.hirsch1
See the image attached
What power must be applied to this object to accelerate it from rest to an angular speed of 2.7 rad/s in 5.2 s about the x axis?
P = W / t - torque * angular velocity
P = [(0.5 m)*(7 kg)*(acceleration)] * 2.7 rad/s
I don't know how to find acceleration or if I am doing this wrong all together. The right answer is 1.3 W. I tried plugging it into the motion equation v = vo + at to get a, that gave me the wrong answer.
The work goes into making the system have kinetic energy. Your starting point should be P = KE/time. Now you just have to figure out how much rotational kinetic energy it has when ω = 2.7 rad/s.
