Thread Closed
Finding the Displacement of a piston in circular motion
Share Thread Thread Tools
Nov22-09, 03:40 PM   #1
A 1.86 g piston is attached to a rotating disc. The radius is 25.5 cm when the disc is stationary. A spring attached to the piston has a spring constant of 31.3 N/m. The piston is rotating at a frequency of 10 Hz. How har will the piston move outward
k = 31.3
r = 25.5 cm = 0.255 m
Frequency = 10 Hz
m = 1.86 g
2. Relevant equations
1/2kx^2 = Es
ac = v^2/r
W = change in Energy
3. The attempt at a solution
I really don't even know where to start. Please help. How am I supposed to relate frequency to speed?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Nov22-09, 04:16 PM   #2
Recognitions:
Homework Helper Homework Help
Does that mean the piston's centrifugal force stretches the spring?
If so, begin with centrifugal force = spring force
Fill in the detailed formulas and see if you can find the stretch.
Nov22-09, 04:42 PM   #3
Okay so
Fc = -kx
m*ac = -31.3* x
0.00186*v^2/0.255 = -31.3* x
How do I find both v and x?
Nov22-09, 05:46 PM   #4
Recognitions:
You can write another equation using the 10 turns per second.
That is v = 2πr*10.
The question is not very clear, but looks like r = 0.255 + x.
You have a system of two equations to solve.
Nov22-09, 08:36 PM   #5
I found the strech of the spring to be 1.525 cm. Is that all I have to do for this problem?
Nov22-09, 11:07 PM   #6
Recognitions:
The stretch is the answer but that 1.5 cm seems low.
It would be interesting to see how you worked it out.
Thread Closed
Thread Tools
Similar Threads for: Finding the Displacement of a piston in circular motion
Thread Forum Replies
linear displacement in a circular motion Advanced Physics Homework 0
2D motion finding displacement direction and velocity Introductory Physics Homework 6
simple harmonic motion, finding displacement given time... Introductory Physics Homework 1
finding a in circular motion problem Introductory Physics Homework 4
