Closed system piston cylinder device problem
The problem involves a closed system consisting of a cylinder with a frictionless piston containing a perfect gas. The gas undergoes expansion at a constant pressure while heat is supplied, and the task is to calculate the heat supplied during this process.
  • Participants discuss the use of the ideal gas law to find temperatures at different volumes and the relationship between internal energy, work done, and heat flow. There are questions about the calculation of specific heat capacities and the concept of degrees of freedom in gases.
Some participants have provided guidance on using the ideal gas law and the relationship between internal energy and work. There is ongoing exploration of the implications of degrees of freedom on heat capacity, with no explicit consensus reached on the best approach yet.
Participants are navigating definitions and concepts related to gas behavior, including degrees of freedom and their impact on heat capacity, which may not have been previously encountered by all contributors.
ricof
A closed system comprising a cylinder and frictionless piston contains 1kg of a perfect gas of which molecular mass is 26. The piston is loaded so that the pressure is constant at 200kPa. Heat is supplied causing the gas to expand from 0.5m^3 to 1m^3. Calculate heat supplied
w = int-(PdV)
PV = nRT
q = du - w
I have worked out w as 100kJ by doing PdV = 200kPa x 0.5
Oh and Cp = 1.08 kJ/kg/K
Now am stuck.
How did you get this? What is Oh?
You can determine the beginning and ending temperatures of the gas using the ideal gas equation.
Then determine the change in internal energy of the gas: [itex]\Delta U = nC_v\Delta T[/itex]. Add that to the work done (which you have found) and that will give you the heat flow.
OR, as this is a process at constant pressure, you can simply use [tex]Q = nC_p\Delta T[/tex]
Either way, however, you need to know the degrees of freedom of the gas. It is not monatomic as it would have to be iron. So it has either 2 or 3 degrees of freedom.
AM
Sorry, 'Oh' as in the figure of speech.
So I use ideal gas law with the same P but different V each time to find the temperatures?
What does degree of freedom mean? I haven't heard of that before.
Correct.
It is part of the kinetic theory of gases. See: http://en.wikipedia.org/wiki/Kinetic_theory
A monatomic gas has 3 degrees of freedom (of translational motion). A diatomic molecule has 5 degrees of freedom (because it can also spin on two perpendicular axes) and a polyatomic molecule has even more degrees of freedom (because it may be able to rotate on 3 axes and may also vibrate in different ways depending on its structure). Energy absorbed by a monatomic gas all goes into translational energy (which directly increases temperature and pressure). Energy absorbed by diatomic and polyatomic gases goes into rotational and vibrational energy, which does not affect temperature or pressure. So the number of degrees of freedom determines the heat capacity of the gas.
AM
12K
