Complex Analysis - Essential Singularities and Poles
The discussion revolves around finding two analytic functions, f and g, that share a common essential singularity at z=0, while their product results in a pole of order 5 at the same point. The context is rooted in complex analysis, specifically focusing on the behavior of functions near singularities.
  • Participants discuss the nature of essential singularities and poles, considering the implications of Laurent series expansions. There is an exploration of how to construct functions that meet the specified criteria, with some participants suggesting methods to cancel the essential parts of the singularities in the product.
Several participants have shared their attempts at constructing the functions, with one participant expressing doubt about the triviality of their solution. Others have provided their work in detail, seeking confirmation of their findings. The discussion reflects a mix of confidence and uncertainty regarding the proposed functions and their properties.
Participants are navigating the complexities of function behavior at singularities, with some expressing concerns about the validity of their approaches. There is an emphasis on ensuring that the functions maintain essential singularities while achieving the desired pole in the product.
Dan7620
Find two analytic functions f and g with common essential singularity at z=0, but the product function f(z)g(z) has a pole of order 5 at z=0.
Not an equation per say, but I'm thinking of the desired functions in terms of their respective Laurent series centered around 0 (which exist since the functions are analytic.)
1. I know that any function with an essential singularity at z=0 will have an infinite number of negative powers of z when expressed as a Laurent Series.
2.I also know that if the product function has a pole of order 5, then its Laurent series will have a finite number terms in negative powers of z (...5 terms max?).
With this knowledge, I wrote out the general Laurent series of f(z) and g(z), found their product (convolution of the series) and am now trying to find two functions f(z) and g(z) such that the resultant series has 5 terms with negative powers of z.
Needless to say, I'm stuck and I would greatly appreciate any input here. Thanks for your time.
It might be easier if you think of a function f(z) which has an essential singularity at z=0 and then concoct a function g(z) so that the essential part of the singularity cancels in the product.
OK I believe I've solved the problem... both these functions f and g should have essential singularities at z=0, and their product has a pole of order 5 at zero:
[tex] f\left( z \right)=e^{\frac{1}{z}}[/tex]
[tex] g\left( z \right)=\frac{1}{e^{\frac{1}{z}}z^{5}}[/tex]
Would anyone mind confirming this? Thanks
Can I confirm it? Or are you feeling insecure?
I'm a little doubtful because this solution seems trivial, but for the sake of completeness, here is my work:
[tex] f\left( z \right)=\sum_{n\; =\; 0\; }^{\infty }{\frac{1}{n!z^{n}}}[/tex]
[tex] g\left( z \right)=\frac{1}{z^{5}}\left( \sum_{n\; =\; 0}^{\infty }{\frac{\left( -\frac{1}{z} \right)^{n}}{n!}} \right)=\sum_{n\; =\; 0}^{\infty }{\frac{\left( -1 \right)^{n}}{n!z^{n+5}}}[/tex]
and clearly the product function
[tex] f\left( z \right)g\left( z \right)=\frac{1}{z^{5}}[/tex]
Looking at the Laurent series expressions for f and g it shows that they both have essential singularities at z=0 (b/c of the infinite number of terms with negative powers of z), while the product has a pole of order 5.
Could you confirm this?
Thanks
Thanks
I think that's just fine.
  • · Replies 17 ·
