Verify Trig Identity: Find x so 1-sin(x) = 1
  • Thread starter Thread starter Stevo6754
    Identity Trig
The discussion revolves around verifying a trigonometric identity involving the expression \(\frac{\cos(-x)}{\sin(x) \cot(-x)} = 1\). Participants are tasked with determining whether this is an identity and, if not, finding a value of \(x\) for which both sides are defined but not equal.
  • Participants discuss simplifying the left-hand side of the equation and question the steps taken in the simplification process. There is uncertainty about how to find a specific value of \(x\) where the expression is defined but does not equal one.
Some participants have provided insights into the simplification process and noted that the expression is defined almost everywhere, while others are exploring different values of \(x\) that meet the criteria. There is no explicit consensus on the approach to finding a suitable \(x\) value, but guidance has been offered regarding the conditions under which the expression is defined.
Participants highlight the need to ensure that \(\sin(x) \neq 0\) and \(\cos(x) \neq 0\) for the expression to be defined. Various angles such as \(\pi/4\) and \(\pi/3\) are mentioned as potential candidates for \(x\).
Stevo6754
Use a graphing calculator to test whether the following is an identity. If it is an identity, verify it. If it is not an identity, find a value of x for which both sides are defined but not equal.
[tex]\frac{cos(-x)}{sin(x)cot(-x)}[/tex]=1
None
Ok, plug in the left side for y1, right side for y2, obviously not an identity. The second part where it ask for a x value is where I am having trouble. I thought maybe simplify the left hand side and find a value for whatever that is that equals 1..
Cos(-x)/sin(X)(1/-tan(X))
Cos(x)/sin(x)(-cosx/sinx)
Cos(x)/-cos(x)
Cos(x)/1-sin(x)
Cos(x)-Sin(x)cos(x)
Factor out to get
1-sin(x)
ok so now I have 1-sin(x)=1
-sin(x)=0
so find the value where -sin(x)=0??
The teachers answer is - Not an identity, x=[tex]\pi/4[/tex]
Im clueless about the second part I guess..
so, you simplified it to the form of Cos(x)/-cos(x). This just equals -1. (your next step was incorrect, though... how did you get from -cos(x) to 1-sin(x)?)
So it obviously is not equal to one. The problem statement asks for "a value of x for which both sides are defined but not equal". We have just shown that whenever the expression is defined, the equation doesn't hold. So you just need to find a value where the expression is defined.
Yeah your right should be -1, I'm not quite sure how I would go about finding a value where the expression is defined.
Anyone? That was my original question, I am not sure how to find that value.
It's defined almost everywhere. Since cot(-x)=-cos(x)/sin(x), you need to make sure sin(x)=/=0.
Then you also need to make sure that the simplified expression, cos(x)/-cos(x) is defined, i.e. cos(x)=/=0.
That's all. There are plenty of angles for which this holds. pi/4 is one, but you can also have pi/3, 2*pi/3, etc..
Stevo6754, since you're able to simplify the expression and make it [tex]\frac{cos(-x)}{sinxcot(-x)}=-1[/tex], this is telling you that for all defined values of x (they are undefined where the denominator=0) it is not equal to 1. So like grief has said, the values you're looking for are not just [itex]\pi/4[/itex] but any other value that is defined.
Oh and while [itex]cos^2x=1-sin^2x[/itex] this does not mean [itex]cosx=1-sinx[/itex] since, if you square both sides you'll get [itex]cos^2x=(1-sinx)^2=1-2sinx+sin^2x\neq 1-sin^2x[/itex]
