Trigonometry: if a = sinx+cosx and b=tanx+cotx, then a(b^2-1)-2 = ?
In summary: I will try again.In summary, the equation a(b^2-1)-2 has the value sin^2(x)+cos^2(x) for all values of ##x##.
Crystal037
167
if a = sinx+cosx and b=tanx+cotx, then the value of a(b^2-1)-2 is
sin^2(x)+cos^2(x)
b^2-1= tan^2(x) + cot^2(x) + 2 -1
b^2-1= sin^2(x)/cos^2(x) +cos^2(x)/sin^2(x) -1
b^2-1=[sin^4(x) +cos^4(x)]/sin^2(x)cos^2(x) -1
b^2-1=[1-sin^2(x)cos^2(x)]/sin^2(x)cos^2(x) -1
a(b^2-1)=sinx+cosx {[1-sin^2(x)cos^2(x)]/sin^2(x)cos^2(x) -1 }
I am not able to go any further than this step to reach the answer
Crystal037 said:
Homework Statement: if a = sinx+cosx and b=tanx+cotx, then the value of a(b^2-1)-2 is
Homework Equations: sin^2(x)+cos^2(x)
I am not sure what answer you are looking for, but this might help. What do get when you write ##b## in the form ##b = \frac {? + ?} {sin(x)cos(x)}##?
I'll get sin^2(x)+cos^2(x) which is 1
the answer should be 0
But I don't know how to further proceed please give me a hint
Did you make an error when you copied or typed the the problem?
If you interchange the definitions for ##a## and ##b## you will get the desired result.
Did you not try some values of ##x## to see whether you get 0? If the expression is identically 0, then that means it's 0 for every value of ##x##.
Why not try at least one value of ##x##?
Thank you, I think the question is wrongly printed
1. What is the formula for "a(b^2-1)-2" in terms of trigonometric functions?
The formula for "a(b^2-1)-2" is a(sin^2x+cos^2x)(tan^2x+cot^2x)-2.
2. How can I simplify "a(b^2-1)-2" using trigonometric identities?
To simplify "a(b^2-1)-2," we can use the Pythagorean identity (sin^2x+cos^2x=1) and the identity for the sum of tangents (tanx+cotx=1). This simplifies the formula to just a-2.
3. Can "a(b^2-1)-2" be rewritten in terms of only one trigonometric function?
No, "a(b^2-1)-2" cannot be rewritten in terms of only one trigonometric function because it involves both sine and cosine (in the form of sin^2x and cos^2x) as well as tangent and cotangent (in the form of tan^2x and cot^2x).
4. How can I solve for x in the equation a(b^2-1)-2 = 0?
To solve for x in the equation a(b^2-1)-2 = 0, we can use algebraic methods such as factoring and the quadratic formula to isolate and solve for x. The final solution will be in the form of an inverse trigonometric function.
5. What are the possible values of x in the equation a(b^2-1)-2 = 0?
The possible values of x in the equation a(b^2-1)-2 = 0 depend on the values of a and b. Generally, there will be an infinite number of solutions, but they will be restricted to certain intervals based on the values of a and b. These intervals can be found by graphing the equation or using a calculator or computer to solve for the zeros of the function.
