How Fast is the Distance Changing Between Two Ships and a Man's Shadow?
  • Context: Undergrad
  • Thread starter Thread starter aMo0oDi
    Hard
The discussion revolves around two calculus problems involving rates of change: the distance between two ships moving in different directions and the length of a man's shadow on a wall as he walks towards it. The scope includes mathematical reasoning and application of calculus concepts.
  • Homework-related
  • Participants discuss the equations of motion for ship A and ship B, with ship A moving east and ship B moving north, leading to a distance formula based on the Pythagorean theorem.
  • One participant derives the distance formula as D = √((35t - 150)² + (25t)²) and differentiates it to find the rate of change of distance.
  • Another participant expresses uncertainty about their calculations, suggesting a much higher rate of separation (around 5000 km/h), which prompts skepticism from others regarding the plausibility of such a result.
  • One participant proposes a rate of separation of 21.4 km/h, questioning the previous high value and suggesting that the maximum rate should be the sum of their speeds (60 km/h).
  • For the second problem, participants discuss the scenario of a man walking towards a wall and the resulting shadow length, with one participant calculating a speed of 1.01 m/s for the shadow's decrease.
  • Another participant shares a method involving the use of the Pythagorean theorem to find the hypotenuse and subsequently the speed of the shadow's decrease, expressing uncertainty about the correctness of their approach.
There is no consensus on the correct rates of change for the first problem, with participants presenting differing calculations and interpretations. The second problem also lacks agreement, as participants arrive at different conclusions regarding the speed of the shadow's decrease.
Participants express uncertainty in their calculations and reasoning, indicating potential limitations in their understanding of the problems. The discussion includes various assumptions about the setup and the application of calculus principles.
aMo0oDi
Hi guys.. i was studying calculus and i found some problems in solving these two questions.. would you please help me to figure out the answers?
1) At noon ship A is 150 km west of ship B. Ship A is sailing East at 35 km/h and ship B is sailing North at 25 km/h. How fast is the dstance between the ships changing at 4 pm?
2) a spotlight on the ground shines on a wall 12 meters away. if a man 2 meters tall walks for the spotlight toward the building at a speed of 1.6 meter per second, how fast is the length of his shadow on the building decreasing when he is 4 meters from the building?
1) Think of ship A traveling right on the x-axis, starting at the point (-150,0). Think of ship B traveling up on the y-axis, initially at (0,0). Let A represent ship A's distance from the origin, and B represent B's distance from the origin. The distance between the two ships is:
[tex]\sqrt{A^2 + B^2}[/tex]
If you think about it, place ship A at any point on the x-axis and B at any point on the y-axis, and you'll see the distance between the ships is the hypoteneuse of a triangle, whose arms are the segment from the origin to ship A, and the segment from the origin to ship B. and given the lengths of two arms of a right triangle, you know how to find the length of the hypoteneuse by Pythagorean Theorem, which is how I got the equation above. Now, how do we express A and B in terms of time? Let t represent time, in hours.
A = -150 + 35t
B = 0 + 25t
You should be able to see clearly why the equations above are right. If not, maybe try plotting the position of each ship after a bit of time goes on, and notice how the distances to the origin are properly described by those equations. Now, going back to the distance, let's call it D:
[tex]D = \sqrt{A^2 + B^2}[/tex]
[tex]D = \sqrt{(35t - 150)^2 + (25t)^2}[/tex]
[tex]D = \sqrt{1850t^2 - 10500t + 22500}[/tex]
Now, to find the rate of change of distance with respect to time, differentiate D with respect to t:
[tex]dD/dt = \frac{3700t - 10500}{2\sqrt{1850t^2 - 10500t + 22500}}[/tex]
To find the rate of change of distance at 4 p.m., that is 4 hours later, plug in t=4, and you'll have your answer.
well its been awhile sense I've done these but...draw the orginal situation and u find ship A's equation of motion is x(t) = 35t - 150 and B's is y(t) = 25t
the distance between two points in a flat plane is [tex]d = sqrt{(x - x_o)^2 -(y - y_0)^2}[/tex], but u see A's motion is only on the x axis... so x_0 = 0 and... also for B y_0 = 0 so sub the eq's for x and y u get...
[tex]d = sqrt{(35t - 150)^2 + (25t)^2}[/tex]
dd/dt = change of distance/change of time
dd/dt = 1250t + 70(35t-150)/(2 sqrt(625t^2 + (35t - 150)^2)) and t = 4 so the answer...4,996.517 km/h
i have no idea if this is right lol but check it out lol
I got an answer of something like 21.4 km/h. Did you really get something like 5000 km/h? How could they possibly be moving away from each other at that rate? Even if they were headed in opposite directions they could only be separating at a rate of 25+35=60 km/h, right?
AKG, I think your answer sounds correct.
thanks a lot for helping us figuring out the way of solving the first problem.. what about the second one?
2) a spotlight on the ground shines on a wall 12 meters away. if a man 2 meters tall walks from the spotlight toward the building at a speed of 1.6 meter per second, how fast is the length of his shadow on the building decreasing when he is 4 meters from the building?
i got 1.01 m/s is that correct ..
I did it by using x^2+y^2= z^2
x=8 y= 2
i found the hyp as equal to 8.24 m b
soo i used it to get the time which is 7.5 s T=d/s T=12/1.6
then i used the time with the hyp to get the speed . which is s=d/t
8.24/7.5 = s
im wondering is that correct ??
http://calclab.math.tamu.edu/~belmonte/m151/L/c3/L3A.pdf
  • · Replies 21 ·
  • · Replies 17 ·
