Find the Frequency of Infrared Radiation with Wavelength 160.432 µm
The discussion revolves around calculating the frequency of infrared radiation given its wavelength of 160.432 micrometers, using the speed of light as a constant. Participants are exploring the relationship between wavelength and frequency in the context of electromagnetic radiation.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the formula relating speed, wavelength, and frequency, with one participant attempting to convert units and calculate frequency. Questions arise regarding unit conversions and the accuracy of the calculations.
Some participants have provided guidance on identifying missing units in calculations, while others have confirmed the correctness of the approach taken. Multiple interpretations of the calculations are being explored, with an emphasis on unit consistency.
There is mention of potential mistakes in unit conversion, particularly when converting micrometers to meters, which may affect the accuracy of the final answer. Participants are also working under the constraints of an online homework system that limits attempts.
stacker
What is the frequency (in Hz) of infared radiation that has a wavelength of 160.432 micrometers? The speed of light is 3.00 x 108 m/s.
Speed of light = wavelength x frequency
Speed of light = 3.00 x 10^8 m/s
I know that the speed of light is equal to wavelength multiplied by frequency and that this question is basically just plug and chug. But I keep getting the wrong answer. What I did is I converted 160.432 micrometers into meters, which is 1.60432 x 10-4. Then I divided 3 x 108 (m/s) by 1.60432 x 10-4 (m). I get the value of 1.86995 x 1012. I convert this value to nanometers: 1.86 x 1021. This is the wrong answer! What did I do wrong?
What units are missing from your value 1.86995 x 1012? Figure that out and you may notice where you went wrong.
I think I figured it out: [3 x 108 (m/s)/ 160.432 micrometers] x [106 micrometers/ 1 meter] = 1.869951132 x 10^12
Could you reply back and check if this is the right answer because I think I have only one more shot at getting this right on my online homework.
Again, you're missing the units from your answer. But assuming the missing unit is Hz (as the problem requests), you seem to have done it correctly.
I went ahead and checked it. I got it right. Thank you.
Such a conversion adds another possible occasion to make a mistake. I would enter 160.432 X 10-6 into the calculator.
9K
