Water flowing in and out of a bucket
  • Thread starter Thread starter Pinkk
    Water
The discussion centers on calculating the height (h) of water in a cylindrical bucket being filled at a rate of 2 * 10^(-3) m^3/s while simultaneously leaking from a hole at the bottom. The bucket has a diameter of 1.5 m and a height of 2.5 m, with a hole diameter of 3 cm. The equilibrium height is reached when the inflow rate equals the outflow rate, which can be determined using the principles of fluid dynamics, specifically Bernoulli's equation and the area-velocity relationship (A1v1 = A2v2).
  • Understanding of fluid dynamics principles, particularly Bernoulli's equation.
  • Knowledge of area-velocity relationships in fluid flow (A1v1 = A2v2).
  • Basic concepts of cylindrical volume calculations.
  • Familiarity with units of measurement in fluid dynamics (m^3/s, m).
  • Study Bernoulli's equation and its applications in fluid flow scenarios.
  • Learn to calculate flow rates using the area-velocity relationship (A1v1 = A2v2).
  • Explore cylindrical volume calculations to understand water levels in containers.
  • Investigate the effects of hole diameter on outflow rates in fluid systems.
Students in physics or engineering courses, particularly those focusing on fluid dynamics, as well as educators seeking to explain the principles of fluid flow and equilibrium in practical scenarios.
Pinkk
A cylindrical bucket is being filled with water at the rate of 2 * 10^(-3) m^3/s. The bucket itself is od diameter 1.5 m and height 2.5 m. The bucket has a small circular hole at the bottom, with diameter 3 cm. Therefore even as the bucket is being filled, there is a leakage from the bottom. At first, the water rises in the bucket. Eventually, the water stops rising when it reaches a height of h. At this point the leakage from the bottom of the bucket equals the water intake from the tap. Find this height h.
I am not sure, we barely covered this in my class. I'm guessing A1v1 = A2v2 and Bernoulli's equation come into play somehow.
I really haven't attempted it because as I stated we did really go over this so much in my class.
Thanks!
The level of water in the bucket will stop rising when the volume of inflow is equal to A2V2.
Volume of inflow and A2 is known. Find V2.
The pressure on the top and bottom of the bucket is the same i.e. atmospheric pressure.
At the opening at the bottom V1 is almost zero. Potential energy with respect to the bottom of the bucket is ρgh. Using Bernoulli equation find h.
