How Much Power Can a 20A Diode Dissipate in Normal vs. Abnormal Conditions?
The power dissipation of a 20A diode is calculated by multiplying the voltage across it by the current flowing through it. For a typical power diode with a constant voltage of 1V, if it conducts 6A, the power dissipation is 6 watts. The maximum current rating of 20A indicates the diode's capacity under optimal conditions with a suitable heatsink. The peak inverse voltage (P.I.V) is the maximum voltage across the diode when it is not conducting, which does not contribute to power dissipation.
  • Understanding of diode characteristics and specifications
  • Knowledge of power calculations in electrical circuits
  • Familiarity with peak inverse voltage (P.I.V) concepts
  • Experience with thermal management in electronic components
  • Research power dissipation calculations for different types of diodes
  • Learn about thermal management techniques for high-current diodes
  • Investigate the effects of peak inverse voltage on diode performance
  • Explore the specifications and ratings of various power diodes
Electrical engineers, electronics hobbyists, and anyone involved in designing or analyzing circuits that utilize power diodes.
newbieI&E
Question requires a definition and typical values during normal/abnormal operation (Power dissipation of 20A Diode with 1V across it)
Have got definition no problems, but am struggling with typical values.
Power dissipated would be in watts, but in order to provide that you would need either circuit current or resistance of diode (of which I have neither)
Note from tutor specifies reference to Current rating, so am tending to think he wants something about the P.I.V rating, but if so, I don't see how to define that in terms of normal/abnormal operation.
If someone could point me in the right direction would be much apprieciated.
Thanks
The power dissipated in a diode would be the voltage across it times the current flowing in it.
The voltage is a fairly constant 1 volt for a power diode.
Suppose it was conducting 6 amps, then the power would be (1 volt * 6 amps) = 6 watts.
The 20 amp rating is the maximum current the diode can carry with a suitable heatsink. So, you could work out the power if it was conducting 20 amps.
The peak inverse voltage refers to the maximum voltage that can occur across the diode when it is not conducting. So this would not dissipate any power.
  • · Replies 69 ·
18K
