Electric Field from Permanent Magnet
The discussion focuses on calculating the electric field generated by a permanently magnetized slab and a spinning magnetized sphere. The slab has a uniform magnetization \textbf{M} = (0, M, 0) and thickness d, while the sphere has a uniform magnetization \textbf{M} = (0, 0, M) and radius r. The key equations discussed include the surface magnetic charge density \sigma_{m, n} = \textbf{M} \cdot \textbf{n} and the volume magnetic charge density \rho_{m} = - \nabla \cdot \textbf{M}. The solution approach involves using duality transformations from Griffiths' Electrodynamics to relate electric and magnetic fields.
  • Understanding of Maxwell's equations and their applications.
  • Familiarity with magnetic charge density and surface current concepts.
  • Knowledge of Griffiths' Electrodynamics, particularly duality transformations.
  • Basic principles of electromagnetism, including electric and magnetic fields.
  • Study Griffiths' Electrodynamics, focusing on duality transformations and their implications.
  • Learn about the derivation and applications of magnetic charge density and surface current.
  • Explore the relationship between electric fields and polarization in magnetized materials.
  • Investigate advanced topics in electromagnetism, such as the implications of moving magnetic fields on electric fields.
Students and professionals in physics, particularly those specializing in electromagnetism, as well as educators looking for insights into teaching concepts related to magnetic fields and electric fields generated by magnetized materials.
insomniac392
Hello,
I've been extremely stuck on the following problems and was hoping someone could give me a push in the right direction:
1) Given an infinite slab of permanently magnetized matter of thickness d centered on the xy-plane with uniform magnetization [tex]\textbf{M} = (0, M, 0)[/tex] and velocity [tex]\textbf{v} = (v, 0, 0)[/tex], find the electric field at [tex]\textbf{E}(0, 0, 0)[/tex] and [tex]\textbf{E}(0, y, 0)[/tex] where y > d.
2) A magnetized sphere with uniform magnetization [tex]\textbf{M} = (0, 0, M)[/tex] and radius r is spinning at a rate of [tex]\textbf{\omega} = (0, 0, \omega)[/tex]. Find the electric field for r' > r. (Hint: Find the equivalent magnetic charge density, [tex]\rho_m[/tex], and equivalent surface current, [tex]\sigma_m[/tex].)
I'm not entirely sure (hence the thread)!
[tex]\sigma_{m, n} = \textbf{M} \cdot \textbf{n}[/tex]
[tex]\rho_{m} = - \nabla \cdot \textbf{M}[/tex]
...these are factors of the integrand that give rise to the magnetic scalar potential, [tex]\Omega[/tex], which in turn yields [tex]\textbf{B}[/tex] via [tex]\textbf{H} = - \nabla \Omega[/tex].
I'm desperately stuck on these; for both problems I can find [tex]\rho_m[/tex] and [tex]\sigma_m[/tex], but I don't see the connection to the [tex]\textbf{E}[/tex]-field. Any suggestions to get me started would be greatly appreciated.
insomniac392 said:
Hello,
Well, after doing some digging I found the following problem (7.60) in Griffiths' Electrodynamics:
Maxwell's equations are invariant under the following duality transformations
[tex]\textbf{E'} = \textbf{E} cos(\alpha) + c \textbf{B} sin(\alpha)[/tex]
[tex]c \textbf{B'} = c \textbf{B} cos(\alpha) - \textbf{E} sin(\alpha)[/tex]
[tex]c q_{e}' = c q_{e} cos(\alpha) + q_{m} sin(\alpha)[/tex]
[tex]q_{m}' = q_{m} cos(\alpha) - c q_{e} sin(\alpha)[/tex]
...where [tex]c = 1/\sqrt{\epsilon_0 \mu_0}[/tex], [tex]q_m[/tex] is the magnetic charge and [tex]\alpha[/tex] is an arbitrary rotation angle in "[tex]\textbf{E}-\textbf{B}[/tex] space."
Griffiths' says that, "this means, in particular, that if you know the fields produced by a configuration of electric charge, you can immediately (using [tex]\alpha = \pi / 2[/tex]) write down the fields produced by the corresponding arrangement of magnetic charge."
Thus, if I were to solve for [tex]\textbf{E}[/tex] in (1) and (2) with a polarization [tex]\textbf{P}[/tex] instead of a magnetization [tex]\textbf{M}[/tex], I could then use a duality transformation to find the solutions to (1) and (2), correct?
  • · Replies 26 ·
