Solving Problems with Old Computer: Graphics Card and Internet Issues
  • Thread starter Thread starter whiteboy
    Computer
The discussion revolves around troubleshooting issues with an old computer, specifically focusing on problems related to a graphics card, internet connectivity, and potential hardware failures. Participants explore various diagnostic approaches and possible causes for the computer's malfunctions.
  • One participant suggests testing a spare video card to determine if the original graphics card is faulty.
  • Another mentions potential RAM issues and recommends using diagnostic tools like DocMemory to check for compatibility problems.
  • Concerns are raised about the hard drive possibly being damaged, which could affect virtual memory and cause crashes.
  • A participant proposes using a lens cleaner for the CD drive, as poorly produced disks may lead to system hangs and blue screens.
  • There is speculation about the possibility of an MBR virus corrupting the Master Boot Record, which could explain the file deletion issues.
  • Participants discuss the importance of checking for known issues specific to Compaq systems and the necessity of using the correct driver disks.
  • One participant raises the question of whether the graphics card was built into the motherboard and suggests that conflicts could arise if old graphics settings were not properly disabled.
  • Another participant notes that timing conflicts may be a factor in the issues experienced with the computer.
  • A brief mention of performing a virus scan is made as a potential troubleshooting step.
Participants express multiple competing views regarding the causes of the computer's issues, with no consensus reached on the primary source of the problems. Various hypotheses about hardware conflicts, potential viruses, and driver issues are presented without resolution.
Participants highlight several limitations in their troubleshooting approaches, including the need for specific driver disks, potential hardware incompatibilities, and the uncertainty surrounding the condition of the hard drive and RAM.
This discussion may be useful for individuals experiencing similar issues with older computers, particularly those related to graphics cards, internet connectivity, and hardware diagnostics.
whiteboy
[SOLVED] Problems w/ Computer
hey ppl, I am havin problems with my old computer i had a nvidia 64mb gforce 4 grapchics card installed and a while before that i had a cd burner put in, after a while the computer started crashing on a regular bases like 4 times a day, then a few days later it started deleting files from the harddrive and 1 day later it had erasef the operating system which was windows98, then to top it off after that the computer would not even turn on, we got the thing fixed and now it runs, but when i try to load the driver for the graphics card a blue screen comes up and says there has been an error with a lot of numbers... then it says press any key to contiue and then the computer freeze's, I've tried other cd's and i get the same thing, I've also tried to get the driver off the net, but now i can't get the net to work on the comp, i plug the phone cord into the router and into the comp, but i get a cannot find server, even though the net is workin cause i got it right next to me on my other comp... i had to buy a new computer cause of this and i would just like to have the other one workin for whatever, the computer is a compaq persario idk why the cd rom drive won't load anything and why my internet on this damn thing won't work if someone could help me out id appreciate it thxs...
Computer science news on Phys.org
A couple of things I would do-
- If you have a spare video card around, try putting that in and see if you have the same issues. If you don't you could have a bad video card.
- I've also seen similar problems with ram issues. I've used DocMemory to diagnose a problem with incompatible memory on an HP machine. It boots into the floppy so avoids OS problems. There are others around. Some companies seem to design their bioses so that they only take 'recommended' memory modules.
- When it's running 'ok' try some sort of harddrive test application. It's possible that if your HD is stuffed that it's screwing with your virtual memory.
- If it's crashing when you are accessing the cd, try getting a lens cleaner. I have some badly produced disks that cause exactly the symptoms you are talking about, hanging and blue screening, when the disk can't be accessed. Try the disk on someone elses pc and see if it locks. If it doesn't you could try copying the drivers to another disk or if your net connection works, try downloading it and installing. I've gotten around the situation by installing a DVD rom which, I think due to the abilities of the DVD laser, is able to read these bad disks.
- The deleting files thing is a worry. I haven't investigated the symptoms or much at all really, but perhaps you have some sort of MBR virus that has corrupted the Master Boot Record on the HD. Maybe do a search for 'MBR virus' and see if you recognise any symptoms.
- Also search the Compaq site for known issues or incompatabilities. You might also have a special driver disk specific to compaq that is designed for the presario in particular. You could run into problems if you don't use it. I know that the person with the memory problem had some issues with not using the original HP disk.
- Other problem might be associated with the motherboard, you could be screwed.
- Internet, are the lights flashing on the lan connection on the back of the PC when you connect the cable?? Do you have the software loaded (TCP/IP etc.). Was everything detected during Windows installation?
- 'Jiggle the cables', the troubleshooter mantra. Make sure all cables are seated properly internally. Make sure your IDE cables aren't damaged. Swap your cards into other PCI slots if you use PCI.
Hope this helps.
Raavin :)
Do not video cards cause many problems (hence safe-mode sans video driver)?
I have one that causes me to lose files and crashes the computer when used with one motherboard, yet it works perfectly when I use it with different motherboard.
I would suspect the video card and its driver/s before I would the CD driver.
You didn't tell us what kind of graphics card you replaced. Was it built into the motherboard? If it is onboard and you did not properly disable the old graphics settings, it could be conflicting with the new one and the conflict could cause all kinds of problems, some of which you described (I'm not sure about the deleting of files, but I guess if it is giving you the BSOD then files could be corrupted and appear deleted).
It does sound more like a timing conflict. I run into it a lot with the job that I do.
But for sure the second thing would be a virus scan
  • · Replies 22 ·
