Definition of Quasi-Fermi Level - Nikolaas Van Der Heyden
  • Thread starter Thread starter marlon
The discussion centers around the definition and implications of the quasi-Fermi level, particularly in the context of semiconductor systems under external influences such as voltage and light. Participants explore its relationship with the Fermi energy and the conditions under which it is applicable, including scenarios of thermal equilibrium and population inversion in semiconductor lasers.
  • Some participants define the Fermi energy as the energy of the highest filled state at absolute zero, with thermal excitation allowing states above it to be filled at higher temperatures.
  • Others propose that the quasi-Fermi level is the effective Fermi level that arises when an external voltage is applied, indicating a shift in the energy distribution of carriers in the system.
  • A participant questions the generation of the quasi-Fermi level and its relation to external voltage versus prior radiation fields used for stimulated emission in semiconductor lasers.
  • One participant elaborates on the Fermi-Dirac distribution and how it changes under bias, suggesting that under certain conditions, different quasi-Fermi levels can be defined for conduction and valence bands.
  • Another participant provides mathematical formulations to describe carrier densities in conduction and valence bands under bias, indicating that the quasi-Fermi levels differ from the original Fermi level due to external influences.
Participants express differing views on the relationship between the quasi-Fermi level, external voltage, and radiation fields. There is no consensus on a singular definition or the underlying processes generating the quasi-Fermi level, indicating ongoing debate and exploration of the topic.
Limitations include assumptions about the conditions under which the quasi-Fermi level is defined, the dependence on external influences, and the mathematical steps involved in deriving carrier densities. The discussion does not resolve these complexities.
marlon
can anyone provide me with a good definition of the quasi-fermi-level?
I know it originates when there is light present in a semiconductor-laser-system, this light is used for the stimulated emission.
thanks
nikolaas van der heyden
marlon,
Please do not crosspost.
The fermi energy is the energy of the highest filled state in a system at absolute zero. At absolute zero, every state with energy below the fermi energy is filled, and every state with energy above it is empty. At temperatures above absolute zero, thermal excitation permits some of the states above the fermi energy to be filled, leaving some below it empty.
- Warren
chroot said:
marlon,
- Warren
... and a quasi-fermi level is the fermi level (chemical potential) that a system takes on when an external voltage is applied.
Quantum Cowboy
Quantum Cowboy
ok, sorry bout the crosspost, won't happen again.
If an external voltage is applied...ok, then how is this new fermi-level generated. What is the underlying process. I don't minde if the explanation is in heavy QM-language, feel free to indulge yourselves, please I insist.
So it has nothing to do with a prior present radiationfield which is then used for stimulated emission. the external voltage is used for population-inversion in semiconductor-lasing-systems, right ?
already thanks for helping me out
grazie mile
Essentially, this is the plot:
When a system (such as a semiconductor) is in thermal equilibrium and no bias (voltage, EM radiation, ecc) is applied, the distribution function that describes the occupation of the quantum states is the Fermi-Dirac distribution (FDD), given by
[itex]f_0(E,E_F,T) = \frac{1}{e^{(E-E_F)/k_B T} +1}[/itex]
where E is the energy of the state, EF is the Fermi energy (also called Fermi level), and T is the temperature. This distribution law is valid for any energy level of the system, independently of the fact that it is above or below the Fermi energy (conduction or valence band state).
When the system is under bias, the FDD doesn't hold anymore. However, if the bias is not to great, or not changing to quickly, it is still possible to describe the occupancy of the quantum states of the different bands using a distribution law of the same form of the FDD, but with different Fermi energy for different bands (One says that there is a situation of quasi-thermal equilibrium). Hence one has
[itex]f_c = f_0(E,E_{F_n},T)[/itex]
[itex]f_v = f_0(E,E_{F_p},T)[/itex]
where fc and fv is the probability of finding an electron in the conduction and valence band, respectively, and EFn and EFp are called the quasi Fermi levels for the conduction and the valence band.
You can look at the topic by this point of view:
Let us suppose that a semiconductor is in thermal equilibrium (no bias). Its density of free carriers in the conduction band (electrons) and in the valence band (holes) is given by
[itex]n = \int_{E_c}^{\infty} {g_c(E) f_0(E, E_F, T) dE}[/itex]
[itex]p = \int_{-\infty}^{E_v} {g_v(E) ( 1 - f_0(E, E_F, T) ) dE}[/itex]
where Ec is the CB minimum, Ev is the VB maximum and gc and gv are the density of state of the CB and VB, respectively. Suppose that a photon field now hits the systems. This rise both n and p and it is impossible to describe this new (quasi) equilibrium by means of the last two formulas, unless one replaces the single parameter EF with the two parameters EFn and EFp:
[itex]n_{bias} = \int_{E_c}^{\infty} {g_c(E) f_0(E, E_{F_n}, T) dE}[/itex]
[itex]p_{bias} = \int_{-\infty}^{E_v} {g_v(E) ( 1 - f_0(E, E_{F_p}, T) ) dE}[/itex]
Physically, the quasi Fermi level relative to a band is the effective Fermi level that brings to the same density of carriers in the same band when the system is not perturbed.
Since, in the example above, [itex]n_{bias} > n[/itex] and [itex]p_{bias} > p[/itex] (photons increase both carrier densities), one has [itex]E_{F_n} > E_F[/itex] and [itex]E_{F_p} < E_F[/itex].
For more details you can read Chapter 3 of The Physics of Solar Cells by J. Nelson or many other books.
14K
20K
