The Lagrangian/Hamiltonian dynamics of a particle moving in a manifold
The discussion focuses on deriving the Equation of Motion (EOM) for a particle of mass 'm' moving in a manifold, utilizing the Lagrangian defined as L={\frac{m}{2}}{g_{ij}(x)}.{\dot{x^{i}}{\dot{x^{j}}}. The user seeks to evaluate the term {\frac{{\partial}L}{{\partial}{x^{i}}}, noting that the Lagrangian does not explicitly depend on the position x^i, only on the velocity \dot{x}^i. The expected result for the derivative is {\frac{{\partial}L}{{\partial}{x^{i}}}= \frac{m}{2} {\partial}_i g_{jk} \dot{x}^{j}\dot{x}^{k} - ({\partial}_k g_{ij}) \dot{x}^{k}\dot{x}^{j}, highlighting the importance of the metric tensor g_{ij}(x) in the analysis.
  • Understanding of Lagrangian mechanics
  • Familiarity with manifold theory
  • Knowledge of metric tensors in differential geometry
  • Proficiency in calculus of variations
  • Study the derivation of the Euler-Lagrange equations
  • Explore the properties of metric tensors in Riemannian geometry
  • Learn about the calculus of variations and its applications in physics
  • Investigate the implications of non-constant metrics on particle dynamics
Students and researchers in theoretical physics, particularly those focusing on classical mechanics, differential geometry, and the dynamics of systems described by Lagrangian formulations.
vertices
I posted this problem on the Classical Mechanics Subforum last week but have not received many responses - hopefully someone can help here as I've spent hours racking my brain, trying to work this out!
There is a particle of mass 'm' moving in a manifold with the following Lagrangian:
[tex] L={\frac{m}{2}}{g_{ij}(x)}.{\dot{x^{i}}{\dot{x^{j} }[/tex]
where
[tex] ds^{2}=g_{ij}(x)dx^{i}dx^{j}[/tex]
is the metric on M.
The question is to find the Equation of Motion - I need to work out:
[tex] {\frac{{\partial}L}{{\partial}{x^{i}}}[/tex]
in order to do this.
To find EOM we need to set the the follow expression to 0:
[tex] {\delta}A=\int{dt[{\frac{{\partial}L}{{\partial}{x^{i}}}dx^{i}+\frac {{\partial}L}{{\partial}\dot{x^{i}}}d{\dot{x^{i}}]}=0[/tex]
It took me a while but I understand why:
[tex] \frac{{\partial}L}{{\partial}\dot{x^{i}}}=mg_ {ij}x^{j}[/tex]
So that's fine.
Now I need to evaluate:
The issue is there is no term in [tex]x^i[/tex] (the position) in the Lagrangian - it is only a function of the velocity [tex]\dot{x}^i[/tex]. And also, why is [tex]g_{ij} = g_{ij}(x)[/tex] - ie. a function of x - as I understand it, it is just a matrix of dim M with diag(-1,1,1,1,1,...).
FYI - the answer to my question should be:
[tex]{\frac{{\partial}L}{{\partial}{x^{i}}}= <br /> \frac{m}{2} {\partial}_i g_{jk} \dot{x}^{j}\dot{x}^{k} - ({\partial}_k g_{ij}) \dot{x}^{k}\dot{x}^{j} [/tex]
I think the Powers That Be on this forum would rather you keep it there:
https://www.physicsforums.com/showthread.php?t=366151
(unless it has been a homework problem all along, then it should have been posted here in the first place...) I'll take it up on that other thread.
  • · Replies 16 ·
  • · Replies 81 ·
