What happens if you drink a large amount of ATP contained in a solution?
  • Thread starter Thread starter royzizzle
Excess ATP consumed in a solution undergoes rapid hydrolysis, reaching an equilibrium state where it cannot be utilized for energy. The body primarily synthesizes ATP through mitochondria, relying on glucose availability, and does not effectively utilize externally sourced ATP due to degradation in the digestive system. Research on AdenylPro, an oral ATP supplement, indicates no significant performance enhancement in muscle output, confirming that external ATP is likely broken down rather than utilized.
  • Understanding of ATP hydrolysis and equilibrium dynamics
  • Knowledge of mitochondrial ATP synthesis and metabolic pathways
  • Familiarity with purinergic signaling mechanisms
  • Basic concepts of digestive system biochemistry
  • Research the biochemical pathways of ATP hydrolysis and its implications
  • Explore mitochondrial function and glucose metabolism in ATP production
  • Investigate purinergic receptors and their role in cellular signaling
  • Examine clinical studies on the efficacy of ATP supplements like AdenylPro
Biochemists, sports nutritionists, fitness professionals, and anyone interested in the metabolic effects of ATP supplementation.
royzizzle
How will your body try to get rid of the excess ATP? will the kidneys get rid of it or will the ATP just sit in your muscles until you use them. or will it not even go to your bloodstream and diarea gets rid of it?
i know this seems like a really stupid question but i haven't taken any biology classes.
thanks
Biology news on Phys.org
I don't know what 'excess ATP' means. If you dissolve ATP in water, it will quickly hydrolyze until equilibrium is reached ([ATP]/[ADP][Pi]), at which point your body cannot get any work out of the solution- and that neglects whether or not the stomach will further degrade ATP and ADP in the pH 1 environment.
AFAIK, your mitochondria crank out ATP as fast as possible; the rate-limiting step is the availability of glucose. I suspect ATP synthesis will continue until the energy cost of creating a molecule of ATP is more than can be obtained by the various metabolic reactions (oxidative phosphorylation and glycolysis).
Also, ATP is a signalling molecule: ATP in the airway fluid, urine, blood, etc. will initiate various signalling pathways via purinergic receptors in epithelial tissue.
http://en.wikipedia.org/wiki/Adenosine_triphosphate
Agree with everything Andy has said. Even if you could use a solution that ATP can just sit in without hydrolyzing the body does not appear to use ATP from external source. There are these pills called AdenylPro which was an a pill to be taken as an oral form of ATP. The theory was that it would increase the amount of time you spend at maximal output for your muscles. After experiments (which I haven't gone to look for, I'm sure you can just search AdenylPro in google) they found that the pills did not help increase anything. No performance effects were noted in the experiment.
One thing we do not know however is exactly what your question originally was: What the body does with external sources of ATP. I think it just gets broken down.
9K
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 130 ·
18K
  • · Replies 287 ·
29K
17K
