How Can You Prove the Law of Cosines Using Coordinates?
  • Thread starter Thread starter huntingrdr
    Law
The discussion revolves around proving the law of cosines using a coordinate system. The law states that for a triangle with sides of lengths a, b, and c, and an angle theta between sides a and b, the relationship c^2 = a^2 + b^2 - 2ab*cos(theta) holds. Participants are exploring how to set up the triangle in a coordinate system to derive this relationship.
  • Participants discuss drawing a triangle in a coordinate system, with sides a and b meeting at the origin and angle theta defined between them. There are attempts to express the coordinates of the triangle's vertices in terms of the sides and angle. Questions arise regarding how to represent x and y coordinates and how to apply the distance formula to find side c.
The discussion is ongoing, with various approaches being suggested. Some participants are questioning the setup and the representation of coordinates, while others are attempting to clarify how to derive the necessary expressions for the proof. There is no explicit consensus yet, but guidance has been offered regarding the relationship between the coordinates and the lengths of the sides.
Participants are working under the constraints of proving the law of cosines without prior knowledge of how to express coordinates in terms of the triangle's sides and angle. There is a focus on understanding the geometric relationships involved.
huntingrdr
Prove the law of cosines: If a triangle has sides with lengths a, b, and c, and theta is the angle between the sides a and b, then c^2 = a^2 + b^2 - 2ab*cos(theta).
Hint: Introduce a coordinate system so that theta is in standard position. Express x and y in terms of theta and then use the distance formula to compute c.
Someone please help me on this. Not sure what is means? Thanks.
Don't know really where to begin or what is means.
Start by drawing a triangle (not a right triangle) in a coordinate system, with sides a and b meeting at the origin. Angle theta is the angle between sides a and b. Find an expression that represents the length of side c.
I drew the triangle and c^2 = a^2 + b^2 - 2abcos(theta). How do I represent x & y in terms of theta and use the distance formula to compute c? x & y are the axis and the point P on the triangle is (x,y).
What do you mean? This is what you're supposed to show.
Sides a and b meet at the origin, and side b is along the x-axis. What are the coordinates for the other end of side a? What are the coordinates for the other end of side b? Use the distance formula to find the length of side c.
The coordinates for the other end of b are (x,y) and the coordinates for the other end of a are (a,0). When I used the distance formula I gt c = sqrt((x-a)^2 + (y)^2). Is this right? How am I suppose to PROVE the law of cosines now?
Forget x and y. Get the coordinates in terms of the lengths of the sides. In your drawing, side a is apparently along the x-axis and side b extends out at an angle theta from the origin. From the endpoint of side b, drop a line segment directly down to the x-axis. Now you have a right triangle inside the larger triangle. What is the x-coordinate at the end of side b? You should be able to write it in terms of b and a trig function involving theta. What is the y-coordinate at the end of side b? You should be able to write it in terms of b and a trig function involving theta.
  • · Replies 16 ·
  • · Replies 19 ·
