Thread Closed
Pressure vessel recertification?
Share Thread Thread Tools
Jan29-10, 10:46 AM   #1
I have a vessel designed, built and certified to ASME Section VIII, Div 1, design rating of 100 psi at a maximum tempeature of 200 F. The new operating conditions for the vessel have changed. It will be operating at a maximum pressure of 30 psi at a maximum temperature of 260 F. Does the vessel need to be recertified based on these new conditions?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan29-10, 12:20 PM   #2
Recognitions:
Gold Membership Gold Member
Need some more information:
1. Was the vessel ever in service?
2. Does the vessel contain a lethal substance?
3. If the vessel was in service is it possible to obtain wall thickness measurements of all of the pressure boundaries?
4. Does the material of construction have a different allowable stress at 260 F?
I would bet that you are probably not going to have to recertify the vessel since the pressure is lower as long as you can show compliancy with the ASME code calculations at the lower pressure and higher temperature.
My company designed a boiler to operate at high pressure and then the client lowered the pressure. The only changes we had to make were to the steam drum and superheater safety valves. No recertification was necessary.
Thanks
Matt
Thread Closed
Thread Tools
Similar Threads for: Pressure vessel recertification?
Thread Forum Replies
Pressure Vessel Design General Engineering 28
Pressure vessel design Engineering Systems & Design 6
Designing a pressure vessel Engineering Systems & Design 3
Explosive pressure in a vessel Materials & Chemical Engineering 2
Pressure Vessel General Physics 3
