| Thread Closed |
Can I prepare Aluminum chloride (hexahydrate) solution frm Aluminum chloride powder? |
Share Thread | Thread Tools |
| Jan31-10, 11:49 PM | #1 |
Is it possible to prepare Aluminum chloride (hexahydrate) solution(15%) from Aluminum chloride powder (ANHYDROUS)? I need it only in small quentities ie. 100ml.
Please help. |
| PhysOrg.com |
chemistry news on PhysOrg.com >> New method for producing clean hydrogen >> Making ice-cream more nutritious with meat left-overs >> Non-wetting fabric drains sweat |
| Feb2-10, 05:00 PM | #2 |
Just add water, stirr, a bit of heat would help but not too much.
Seriously water plus AlCl3 is a very powerful almost explosive reaction, lots of heat comes out of it. So you will have to add the water carefully. A simple method is take your AlCl3 and leave it out in the open for a few days, it will absorb ambient humidity and then adding more water will be by far less explosive. Or add water with a steam bath. Easy to build, take a pot with a lid add hot water in it, and place your AlCl3 in a cup so that it does not get wet or floats, close the lid and wait for a bit. |
| Feb2-10, 05:04 PM | #3 |
... or just leave it out in the moist air. Takes longer. Not as exciting.
| Feb2-10, 10:08 PM | #4 |
| Feb3-10, 09:06 AM | #5 |
Alcohol is for later... evenings in pubs.
All you need to do is (assuming that the 15% is in mass percentage) add 15g of AlCl3hexa to 85g of water. The result will be 15%, but I cannot guarantee that you will end up with 100ml, rather close to that anyway. If the solution should be in alcohol, there should be some mention of that in the formula. The same goes with the percentage for alcohol 85 g, and still no telling how close the volume will be. |
| Feb3-10, 01:02 PM | #6 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Can I prepare Aluminum chloride (hexahydrate) solution frm Aluminum chloride powder?
| Drawing Cobalt Chloride Hexahydrate | Biology, Chemistry & Other Homework | 2 | ||
| Potassium chloride vs. Sodium chloride for osmosis? | Biology, Chemistry & Other Homework | 1 | ||
| Which has higher polarity, sec-butyl chloride or tert-butyl chloride? | Biology, Chemistry & Other Homework | 7 | ||
| Aluminum Chloride Solution | Chemistry | 1 | ||
| Aluminium Chloride | Chemistry | 3 | ||
