Power supply - Importance of amp Rating?
The discussion centers on the compatibility of a power supply rated at 7.5 V DC and 1000 mA with a TV tuner that requires 7.5 V DC and 500 mA. Participants explore the implications of using a power supply with a higher current rating and whether it poses any risk to the device.
  • One participant asserts that a tuner drawing 500 mA at 7.5 volts DC can safely operate on a 7.5 volts DC, 1000 mA supply.
  • Another participant questions the quality of the power supply, suggesting that it should not be a wall-wart type due to potential ripple voltage, which may not provide a smooth DC source.
  • A different participant emphasizes that the power supply can deliver up to 1000 mA, indicating that it can supply the required 500 mA without issues, provided the voltage is the same.
  • Concerns are raised about the electrician's advice that the tuner would eventually burn out, with one participant expressing skepticism about the electrician's qualifications.
Participants generally agree that the voltage must match and that the power supply can provide the necessary current. However, there is disagreement regarding the potential risks associated with using the power supply, particularly concerning the quality of the output and the electrician's warning.
Participants express uncertainty about the implications of ripple voltage from different types of power supplies and the qualifications of the electrician providing advice.
Van Robertson
Power supply -- Importance of amp Rating??
Hello all: I have a TV tuner that requires a DC 7.5 volt, 500 ma power supply. I have a 110 V input power supply rated at 7.5 V DC 1,000 ma. Can I safely use this powersupply with the tuner. Analogy: I can plug a 3.5 am vacuum cleaner into a 15 amp circuit and know that on this 110V A/C circuit, the amperage means that you cannnot simultanously plug in devices collectively drawing more than 15 amps. Likewise, can I safely plug in a 7.5 v 500 ma device into a 7.5 v 1000 ma circuit, and not risk eventual burn-out? An electrician tokld me the tuner would eventually burn out, although it is running fine now. Is he right?
A tuner drawing 500 ma at 7.5 volts dc can run safely on a 7.5 volts dc, 1000 ma supply. Bob S
I would assume that the TV tuner requires a smooth DC source such as from a battery. I don't know what your 7.5V 1000mA supply consists of, but it should probably not be a wall-wart type supply since that would likley produce a lot of ripple voltage instead of a nice smooth DC supply. Your assumption which compares the vacuum cleaner in a residential 15 amp circuit is correct. I hope that the 'electrician' is simply someone who calls himself that. I wouldn't take any advice from someone who tells you this.
The power supply is rated to supply up to 1000mA therefore it can supply any amount of current up to 1000mA. You only need 500mA of power so you will be OK. The important thing is that the voltage is the same and therefore you should have no problems.
http://www.calibrepower.co.uk"
