Differential Equations- homogeneous (I think)
The discussion revolves around finding the general solution of a homogeneous differential equation involving variables x and y, specifically the equation x*y*(dy/dx)=(x^2) + 3(y^2).
  • The original poster attempts to solve the equation by rewriting it in a specific form and applying the method of homogeneous equations. They express confusion about a particular step in their solution process and seek clarification on potential mistakes.
Participants are actively engaging with the original poster's reasoning, with some offering insights into the steps taken. There is an acknowledgment of missed steps, and one participant points out a specific error in the manipulation of terms. The discussion is ongoing, with no explicit consensus reached.
There is a mention of a solution obtained from an external source, Wolfram Alpha, which the original poster references but does not fully understand. The participants are focused on clarifying the steps leading to the original poster's confusion.
StuartSpencer
Find the general solution of the equation
So I start by realizing this is (likely) a homogeneous differential equation, and then rewrite it in the form required:
dy/dx = (x/y) + 3(y/x)
then, using the method of homgeneous equations substitute the variable v, where
v = (y/x), y = vx, dy/dx= v + x(dv/dx)
so I have:
v + x(dv/dx)= (1/v) + 3v
x(dv/dx) = (1/v) + 2v
dx/x = (v + (1/(2v)))dv
then after integrating both sides I get
ln(x) = ((v^2)/2) + (1/2)*ln(v) + C
then substituting back to the original variables I get
ln(x) = ((y^2)/(x^2))*(1/2) + (1/2)*ln(y/x) + C
Now my problem arrives when expressing in the form y(x) = (+ or -)sqrt(c_1 x^6-x^2/2)
which is the solution wolfram alpha got, however wolfram alpha doesn't show how it arrived at this, so I was hoping someone here would, or spot a mistake I made during my solving, or whatever, thank you!
Hi Stuart! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
ooooh … :cry:
(so good up till then! :redface:)
thanks for your comment, but I'm not sure I understand
I can see that I skipped a few steps during that process, but I will show how I arrived there
x(dv/dx)= (1/v) + 2v
dv/dx = ((1/v) + 2v)/x
dv=((1/v)+2v)*dx*1/x
dv/((1/v)+2v) = dx/x
dv*(v+(1/2v))= dx/x
Forgive my ignorance, but I fail to see where I made a mistake, if you can enlighten me I'd appreciate it
Hi Stuart! :smile:
The steps you missed :redface:
dv/((1/v)+2v) = vdv/(1+2v2)
[≠ dv*(v+(1/2v)) = vdv*(1+(1/2v2))]
1/(1 + a) ≠ 1 + 1/a :wink:
How embarassing...I now see the error of my ways, thank you for revealing this to me.
(someone should probably close this thread)
  • · Replies 33 ·
