Energy into a rigid container>Find T2 and P2
  • Thread starter Thread starter boeing9379
    Energy
The discussion focuses on calculating the final temperature (T2) and pressure (P2) of air in a rigid container after a fan draws 1.5 kW of electricity for 30 minutes. The initial conditions are P1 = 1 atm and T1 = 27 degrees Celsius in a 60 m³ volume. The energy input into the system is calculated to be 2700.8 kJ, leading to a work done (W) of -2700.8 kJ due to the insulated nature of the container. The user seeks guidance on connecting energy changes with temperature and volume using the ideal gas law and internal energy equations.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Knowledge of thermodynamic principles, specifically ΔE = Q - W
  • Familiarity with internal energy concepts (ΔU = mc(T2-T1))
  • Basic calculations involving energy conversions (kW to kJ)
  • Study the relationship between internal energy and temperature changes in ideal gases.
  • Learn how to apply the First Law of Thermodynamics in closed systems.
  • Explore the concept of work done in thermodynamic processes, particularly in insulated systems.
  • Investigate the implications of rigid container behavior on pressure and temperature changes.
Students and professionals in thermodynamics, mechanical engineering, and physics who are working on problems related to energy transfer in closed systems, particularly those involving ideal gases and insulated environments.
boeing9379
A Fan draws electricity at a rate of 1.5kW.
The fan is in a well insulated rigid container of air with volume 60 m^3.
Initial pressure and Initial Volume are: P1 = 1 atm, T1 = 27 degrees C.
After 30 minutes, assume Ideal Gas behavior, determine the final Temp and final Pressure.
ΔE = Q - W
PV=nRT
ΔU=mc(T2-T1)?
I calculated the energy into the system to be 2700.8 kJ after 30 minutes. Since there is no ΔKE or ΔPE, ΔE = ΔU = 2700.8 kJ. Since it is well insulated, Q = 0. So W = -2700.8 kJ.
I am having trouble linking the relationship between Energy and Temperature/Volume. I am not sure what other equations to use, so I am making no progress on this problem.
Does anyone have some advice. I will take anything that points me in the right direction, lol.
9K
12K
9K
