How much tension should the rope be able to withstand?
  • Thread starter Thread starter Ryuk1990
    Rope Tension
The discussion revolves around a physics problem involving a rope pulling a 1200 Kg car with an upward acceleration of 0.8 m/s². Participants are exploring the concept of tension in the rope and how it relates to the forces acting on the car.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of net force and the forces acting on the car, including weight and tension. There are questions about the relationship between these forces and how to correctly account for them in the context of the problem.
Participants have engaged in a back-and-forth regarding the forces at play, with some clarifying the roles of tension and weight. Guidance has been provided on the need to consider the direction of forces and the implications for calculating tension.
There is an emphasis on understanding the algebraic sum of forces and the importance of sign conventions in the calculations. Participants are navigating through the assumptions related to the forces acting on the car.
Ryuk1990
A rope is pulling up a 1200 Kg car. The upwards acceleration is 0.8 m/s2. How much tension should the rope be able to withstand?
Net force is equal to mass x acceleration.
So would it just be 1200 Kg x 0.8 m/s2 which is 960 Newtons?
That's the net force. The net force is the algebraic sum of all the forces acting on the car. What are the forces acting on the car?
The normal force and gravity?
Gravity is one force acting down on the car (it's weight). The other force is the contact force (which perhaps you are calling the normal force) which is actually the ___?____ force in the ____?___ which acts ______________(up/down, choose one).
The net force in the system which acts up?
You have already calculated the net (resultant) force. It is equal to 960 N. The net force always acts in the direction of the acceleration, thus, the net force of 960 N acts up. The net force on the car is comprised of 2 forces: the weight of the car, acting down, and the rope tension, which must act up (since the net force is up, the tension force must be greater than the weight force). So you have the tension force acting up, and the weight force acting down, and their net total (algebraic sum) must be 960N .. So the tension force is ?
960 minus the downward force?
No. Please pay heed to your plus and minus signs!
F_net =ma =960 N
the net force must be up (+), in the direction of the acceleration (+).
You have T (the rope tension) acting up (+), and W (the car's weight) acting down (-). T must be greater than W if the net force is up. Thus
T - W = 960. Solve for T, after first calculating W.
Ah that makes sense. Thanks for the help. :-)
  • · Replies 38 ·
  • · Replies 25 ·
