Why are light waves from 2 separate light bulbs incoherent?
The discussion revolves around the coherence of light waves emitted from two separate light bulbs, exploring the reasons for their incoherence. Participants examine concepts related to frequency, phase information, and coherence length, touching on both theoretical and experimental aspects of light behavior.
  • One participant notes that the incoherence arises from the varying wave patterns of light due to energy loss by electrons, questioning how this affects coherence despite the same frequency.
  • Another participant argues that light from a bulb does not have the same frequencies, highlighting that even tiny frequency differences can lead to significant phase differences over time.
  • It is emphasized that phase information is crucial for coherence, and that no real light source, including lasers, produces a perfect sine wave indefinitely. The lack of a definite phase relationship between light from separate bulbs contributes to their incoherence.
  • One participant suggests that a light bulb consists of numerous small emitters that lack phase synchronization, further explaining the incoherence.
  • A later reply elaborates on the relationship between phase incoherence and frequency width in the Fourier transform, indicating that phase jitter corresponds to a non-zero width in the frequency domain.
  • Another participant mentions that interference patterns can still be observed from white light emitted by a single bulb, despite its short coherence length, suggesting that the presence of multiple frequencies is not the sole issue.
  • Temporal coherence is defined in terms of the Fourier transform of spectral power density, with a small frequency spread indicating long coherence time. Spatial coherence is also discussed, noting that distance from the light source can enhance coherence.
  • One participant proposes that filtering light through an optical filter or using a pinhole can increase coherence from a light bulb, although this pertains to classical first-order coherence only.
Participants express multiple competing views regarding the factors contributing to incoherence, particularly around the roles of frequency, phase, and coherence length. The discussion remains unresolved with no consensus on a singular explanation.
Limitations include the dependence on definitions of coherence, unresolved mathematical steps regarding Fourier transforms, and the varying interpretations of coherence in different contexts.
fantasizeme
My notes says that this is due to how the wave patterns of both sets of light waves vary with time since the amplitudes vary due to electrons losing energy. But I don't get how this affects the coherence of both sets of light waves since they have the same frequency
Science news on Phys.org
They don't have the same frequencies. Light from a light bulb has a whole spectrum of frequencies and you only need tiny differences in frequencies to have a 180 degree phase difference after a tiny time.
It's not just a question of frequency. It's the phase information that is important for the concept of coherence. No real light source--even a laser--consists of a perfect sine wave that goes on forever. Even if you take light from a single source and split it and recombine it, making the length difference between the two legs more than the http://en.wikipedia.org/wiki/Coherence_length" , there is no definite relationship between the phase of the two beams and this washes out the interference pattern. In other words, even for a monochromatic laser, there is a finite coherence time beyond which the phases at two different times are completely uncorrelated. Similarly when you have two separate light bulbs as in the original question, there is no definite phase relationship between the light from each source and they are therefore incoherent.
You can actually get an interference pattern from white light coming out of a single light bulb (although the coherence length is very short), so it's not really the presence of many frequencies that is the main issue here.
I'm not sure what is the meaning of the statement that varying amplitudes are the reason for incoherence. I'm not an expert on this, but I'm pretty sure amplitudes are completely irrelevant to coherence.
I'd explain it like this: a light bulb actually contains a huge number of little emitters of light, with nothing to make any of them in phase with each other.
It is maybe nitpicking, but from the moment that there is a phase incoherence, by definition you do not have a single frequency in your Fourier transform. The Fourier transform of a single frequency (a Dirac in frequency domain) is exactly a perfect sine wave that goes on for ever. From the phase coherence, you can derive a minimum width in the frequency domain. If that width is zero, that is, if the light is *perfectly* monochromatic, then it is by definition a single sine. The phase jitter corresponds to a tiny width in the frequency domain - although one might call this light still sloppily "monochromatic" because otherwise you never really have monochromatic light.
Exactly, and this is nothing else but a measurement of the width of the spectral "line". The "finite life time" of a "sine wave" is nothing else but the coherence time (which is the time equivalent of the coherence length), and gives you a measure of the width of the spectral line.
It is! And your example illustrates this. "white" light can be seen as a large "line width" and hence a very short coherence length.
Temporal coherence is basically defined by taking the Fourier transform of the spectral power density and define the decay rate of the transform as the coherence time. Accordingly a small spread in frequencies assumes long temporal coherence and vice versa.
The reason why you can also get interference patterns from white light is spatial coherence. If you go far away from the light bulb you just take a small solid angle of the emission into account. This means that the path differences from the different points on the light source to your detector becomes smaller and therefore coherence is increased. This is why there is a pinhole in front of the double slit in the Young interference experiment. The pinhole mimics a point-like light source which offers full spatial coherence.
Accordingly you can make light from a light bulb as coherent as you like. Filter the light through an optical filter with narrow spectral width and go extremely far away from the source (or put a pinhole in front of it) and you can get arbitrarily high temporal and spatial coherence from a light bulb. However, this works for classical first order coherence only, but not for higher order coherences.
  • · Replies 68 ·
15K
