Convert Strain gauge readings to stress
This discussion focuses on converting strain gauge readings from an I-beam subjected to torsion into stress and shear stress values. The relevant formula for shear stress, τ = Tr/J, is applicable only for closed sections, necessitating the calculation of the polar moment of inertia (J) and the radius (r) for the I-beam. The yield strength and Young's modulus are provided, while the Poisson's ratio is estimated to be between 0.295 and 0.3 for wrought mild steel. The orientation of the strain gauges and the nature of the applied torque are critical factors for accurate stress conversion.
  • Understanding of strain gauge principles and measurements
  • Knowledge of torsion and shear stress calculations
  • Familiarity with Young's modulus and material properties
  • Ability to calculate polar moment of inertia (J) for I-beams
  • Research how to calculate the polar moment of inertia (J) for I-beams
  • Learn about the application of strain gauges in torsion testing
  • Study the effects of Poisson's ratio on stress calculations
  • Explore Omer Blodgett's "Design of Weldments" for detailed explanations on torsion
Engineers, structural analysts, and students involved in materials testing and stress analysis of structural components, particularly those working with I-beams and torsion applications.
howsaboutno
Hello i am trying to convert the strain gauge readings i took in a lab from an I beam that was subjected to torsion. I am trying to convert the microstrain readings to stress and shear stress. I have the following information the Yield strength of the I beam and the youngs modulus but not the poissons ratio.
I thought the formula would be [tex]\tau[/tex]= Tr/J but because it is an I beam i am unsure how to calculate the r and the J. also i know what the T (torsion) that the beam is subjected to.
any help would be very much appreciated.
Tr/J where J is polar moment of inertia only works for closed sections. Long explanation, but the most brief/clear I've seen is Omer Blodgett's in Design of Weldments (and repeated in other texts by the same author) available VERY inexpensively from the J.F. Lincoln Arc Welding Foundation.
(One quick visualization is in applying a torque to a tube, and measure the angular displacement. Then slit one side of the tube lengthwise, and apply the same torque. The displacement will be much larger in the 2nd instance even though the areas and polar moment of inertia will be essentially the same. This is because the torsional shear stress is the same on the plane normal to the axis of the tube as it is on the longitudinal. When you get to the slit, the shear stress has to be zero, because there's nothing there to resist it on the longitudinal plane.)
Young's Modulus and Poisson's ratio depend on the material (and to some degree the form e.g. cast, wrought, etc.). Assuming you have wrought mild steel (structural steel) your Poisson ratio is likely to be 0.295 to 0.3.
What is the orientation of your strain gauge(s) on the I-Beam and was the beam subjected to strictly a torque ?
  • · Replies 61 ·
  • · Replies 30 ·
10K
