What Are the Units of the Green's Function in the Wave Equation?
The Green's function G in the wave equation has units of 1/(m·s), derived from the dimensional analysis of the equation ∇²G - (1/c²)(∂²G/∂t²) = δ(t)δ(r). This analysis ensures dimensional consistency across both sides of the equation, where the right-hand side incorporates spatial and temporal delta functions. The convolution of G with the forcing function f(t), which has units of Pa/m², confirms that the resulting units align with pressure in Pascals (Pa). This establishes the Green's function's role in solving the wave equation accurately.
  • Understanding of wave equations and partial differential equations (PDEs)
  • Familiarity with Green's functions in mathematical physics
  • Knowledge of dimensional analysis in physics
  • Basic concepts of convolution in mathematical operations
  • Study the properties of Green's functions in various PDEs
  • Learn about dimensional analysis techniques in physics
  • Explore the application of convolution in signal processing
  • Investigate the role of delta functions in mathematical modeling
Physicists, mathematicians, and engineers involved in wave propagation analysis, as well as students studying advanced topics in mathematical physics and PDEs.
elgen
Is there a physical unit related to the Green's function of the wave equation?
In particular, let
[tex]\nabla^2 P -\frac{1}{c^2}\frac{\partial^2 P}{\partial t^2} = f(t)[/tex]
where P is pressure in Pa. Since the Green's function solves the PDE when f(t) is the delta function, the Green's function G has a unit of Pa.
The solution to the inhomogeneous PDE is
P = G*f(t),
where * denotes convolution. This leads to contradiction since LHS is in Pa and RHS is in Pa * Pa/m^2 * (sec m^3), where (Pa/m^2) is the unit of f(t) and (sec m^3) denotes the integration in both space and time.
Thx.
Elgen,
Recall the sifting property of the delta function:
[tex]\int_{-\infty}^{\infty} \delta(r) dr = 1.[/tex] With this in mind, we see that the units of RHS (actually both sides) change from the original wave equation once it is replaced with a delta function. This is because the delta function must have units which are the inverse of its argument's units in order to make the sifting property true. So in the example above r has units of distance, and the delta function must therefore have units of 1/distance. The delta function returns a unitless quantity after integration.
Hence, the RHS of [tex]\nabla^2 G -\frac{1}{c^2}\frac{\partial^2 G}{\partial t^2} = \delta(t)\delta(r),[/tex] where G is the Green's function and the RHS contains the necessary spatial and temporal delta functions, has units 1/(m^3*s). To figure out the units of G, we demand that this equation has dimensional consistency among all its terms. Thus, matching units between the second term of the LHS (an arbitrary choice) and the RHS demands that
[tex][-\frac{1}{c^2}]*[\frac{\partial^2 G}{\partial t^2}] = [\delta(t)\delta(r)],[/tex] dimensionally (and only dimensionally!). Thus, [tex][\frac{s^2}{m^2}]*[\frac{G}{s^2}] = [\frac{1}{m^3*s}],[/tex] and (for this example only) G has the following units: [tex][G] = [\frac{1}{m*s}].[/tex] Finally, we check this result by performing the convolution with f(t) from the original wave equation. Remember that f(t) has units Pa/m^2 due to dimensional consistency of the wave equation. Thus, convolving G and f(t) in space and time, we get
[tex]\int [G]*[f(t)]*[dr dt] = [\frac{1}{m*s}]*[\frac{Pa}{m^2}]*[m^3*s] = Pa,[/tex] which are the correct units for pressure.
