Galilean Algebra in the low velocity limit of Poincare Algebra (Weinberg vol 1)
The discussion revolves around the interpretation of statements from Weinberg's Volume 1 on Quantum Field Theory regarding the Galilean algebra and its relationship to the Poincare algebra, particularly in the context of low velocity limits. Participants explore the implications of angular momentum and boost operators in this framework.
  • One participant seeks clarification on the angular momentum operator being of order J ~ 1 and questions how K is of order 1/v.
  • Another participant suggests that K should be of order 1/c instead of 1/v, based on the contraction of the Poincare algebra.
  • A later reply questions whether the contraction being discussed is the Inonu-Wigner contraction and seeks further clarification on the order of J.
  • It is noted that the generators J of SO(3) remain unchanged during the contraction, leading to the conclusion that they are of order 1.
  • One participant speculates that the reference to K being of order 1/v might be a typo, suggesting it should be 1/c instead.
  • Another participant expresses interest in a pedagogical explanation of the contraction process, referencing Robert Gilmore's notes on Lie groups.
Participants express differing views on the order of the boost operator K, with some suggesting it should be 1/c while others initially interpret it as 1/v. There is no consensus on whether the original statement in Weinberg contains a typo.
Participants acknowledge the complexity of the contraction process and the implications for the scaling of operators, but there are unresolved assumptions regarding the definitions and interpretations of the terms involved.
maverick280857
Hi,
Can someone please explain the following statement on page 62 of Weinberg's Vol 1 on QFT:
For a system of particles of typical mass m and typical velocity v, the (..) angular momentum operator is expected to be of order J ~ 1
(I understand the part for P ~ mv, so the "quote" is slightly distorted, intentionally).
Also how is
K of order 1/v
Thanks in advance!
Mmm, I would say that looks a little odd. The Galilean algebra can be obtained by a contraction of the Poincare algebra. In this contraction you scale, in the Poincare algebra, the spatial P_i and K_i by a factor epsilon. Then you calculate again the Lie algebra and take the limit epsilon --> 0. This epsilon can be seen as 1/c, and the contraction can be regarded as sending c to infinity.
The J's constitute the SO(3) subgroup of Poincare which stays untouched, and the boosts will commute. I would say that K is of order 1/c, not 1/v.
Are you referring to the so called Inonu-Wigner contraction here? (I don't know what it is, save a reference in Weinberg on the same page.)
What about J being of order 1? How does that come about?
Yes :) Would you ever find the tendency of wanting to know more about it in a pedagogical way: the notes of Robert Gilmore about Lie groups explain it quite well, in chapter 13.
Well, because in this particular contraction you leave the SO(3) untouched (because SO(3) is a subgroup of both the Poincare as the Galilei group, so you want to keep it), the generators J of SO(3) are not scaled by epsilon. I think that's what Weinberg means, but I'll check his statement.
But I assume you mean by J the [itex]J_i[/itex] which generate the rotations, not the [itex]J_{\mu\nu}[/itex], right?
Ok, I have checked. My guess is that the 1/v of K is a typo, and should be read as 1/c. That would mean that K is of order [itex]\epsilon^{1}[/itex]. The J's are indeed the generators of SO(3), and because of the particular contraction you take they scale like [itex]\epsilon^{0}[/itex].
Otherwise it wouldn't make sense to me :)
Thanks. I'll check out the notes. Right now, I'm unable to reach his website.
But, Weinberg makes it look as if it is possible to get to the Galilean results 'by inspection' (and H = M + W).
  • · Replies 87 ·
9K
  • · Replies 79 ·
19K
  • · Replies 19 ·
  • · Replies 27 ·
