Why does long wavelength infrared not penetrate glass?
Long wavelength infrared (IR) does not penetrate glass due to its molecular structure, specifically the strong absorption bands of silica. Silica absorbs over 99% of IR light at frequencies around 1200 cm-1, leading to complete extinction of wavelengths up to approximately 2500 cm-1. Although glass blocks long wavelength IR, it allows other wavelengths, such as visible light and some blue light, to pass through, which can still generate heat. Different varieties of silica and glass exhibit varying transmission properties, but none significantly transmit IR below 2500 cm-1.
  • Understanding of infrared spectroscopy and absorption bands
  • Knowledge of silica and its chemical properties
  • Familiarity with photon behavior in different materials
  • Basic principles of light transmission and reflection in solids
  • Research the absorption properties of different types of glass and silica
  • Explore infrared spectroscopy techniques for material analysis
  • Learn about the thermal properties of materials in relation to light absorption
  • Investigate the effects of impurities on the optical properties of glass
Material scientists, physicists, and engineers interested in optical properties of materials, as well as anyone involved in designing glass products for specific thermal or optical applications.
quantum123
Science news on Phys.org
Glass is designed to only allow visible wavelength to pass, and once you get to the infrared spectrum glass simply absorbs it.
(http://www.dandydesigns.org/id58.html this kinda explains it)
If that is true, then we would not be able to feel the sun's heat standing beside a closed window.
If I remmeber glass has impurities that block infrared, as pure SiO2 transmits it to some degree.
Btw. the sun light can heat you through a glass window because other wave lengths can heat object too. Blue light is highly energetic foe exemple, an so if absorbed it gives a lot of heat, although in natural light it is not predominant by intensity (# of photons per second).
Long wavelength infrared doesn't penetrate glass because of the molecular-level IR absorbance of the silica. Silica has a *very* strong band at around 1200 cm-1. This band blocks > 99% of the light at that frequency even at very low concentrations (i.e. a few mg of ground up glass in a KBr pellet). So, when you have the bulk material, that band is extremely broad, and produces complete extinction all the way out to ~2500 cm-1 (about 4 microns wavelength), and down to < 200 cm-1 (~ 50 microns). There is another strong band around 3500 cm-1 for the surface terminated Si-OH bonds, but there are no significant absorptions in the near-infrared (i.e. from 4000 cm-1 up to the visible, which starts around 13000 cm-1 or so). The latter point is why you can still feel radiant heat through a glass window pane, as you suspected.
It should be noted that there are many different varieties of silica/glass/quartz, and all of them have different transmission properties, however, non of them transmit to any significant extent at photon energies below 2500 cm-1, as far as I am aware.
TESLACOILZAP said:
Ive always wondered why something as dense as glass or water is transparent
It comes up a lot here - it's probably in the sticky thread, do a search for a more complete answer
In simple terms a photon excites an atom (strictly a bond between atoms)
This then de-excites emitting a new photon. the trick is that in a crystal the atoms are arranged in a regular pattern so the new photon goes off in the same direction.
Glass is a bit tricky, the atoms aren't in a regular pattern like a diamond but they are fixed
In a metal there are lots of free electrons on the surface which absorb any photons, but because these aren't in a regular pattern the emmitted photon goes off in a random direction - so metals are reflective.
Also most commercial glass is also made so that any impurities which absorb visible light are removed, to make it as clear as possible.
  • · Replies 20 ·
  • · Replies 19 ·
