Crystallographic planes and square pyramids
  • Thread starter Thread starter comicnabster
    Planes Square
The discussion focuses on calculating the aspect ratio of an atomic force microscope (AFM) silicon tip shaped like a square pyramid, with each face representing a (111) silicon plane. The tip is etched from a [100] silicon wafer, where the [100] direction is normal to the surface. The participant attempts to relate the (111) planes to the [100] vector using vector notation and the Pythagorean theorem, ultimately deriving that the height of the pyramid is 1/(sqrt2) in relation to the base dimensions. The participant also references the relationship between atomic radius and lattice constant in silicon's diamond crystal structure.
  • Miller indices and crystallographic directions
  • Understanding of silicon's diamond crystal structure
  • Vector notation in crystallography
  • Pythagorean theorem application in three dimensions
  • Study the relationship between Miller indices and crystallographic planes
  • Research the properties of silicon's diamond crystal structure
  • Learn about vector notation in crystallography
  • Explore the application of the Pythagorean theorem in crystallographic calculations
Materials scientists, crystallographers, and students studying solid-state physics who are interested in the geometry of crystallographic planes and their applications in nanotechnology.
comicnabster
In materials science right now we are learning about miller indices and crystallographic directions, including planes.
What is the aspect ratio (height/width) of an AFM (atomic force microscope) silicon tip in the shape of a square pyramid where each face of the pyramid is a (111) silicon plane? The silicon tip is etched out of a [100] silicon wafer. The questions says that for a [100] wafer the [100] direction points normal to the surface.
The book doesn't give any actual equations, only the miller indices definitions, which match what is given on http://en.wikipedia.org/wiki/Miller_index Basically each digit within the brackets represents one of three directions the plane takes, but not the actual value.
Silicon has a diamond crystal structure that is actually two FCC crystal structures offset along the vector (a/4, a/4, a/4) where a represents the lattice constant.
I don't have a good grasp of the crystallographic direction material, unfortunately.
I think the tip of the pyramid relative to the center of the base can be expressed by the miller indices [100] in terms of vector notation. After that it would be a matter of relating the [100] vector to the (111) planes with the Pythagorean theorem.
Would I interpret the (111) plane as having a height of 1 in the z direction and the base having length 1 for both the x and y direction? Then the height would be 1/(sqrt2) (read it as 1 over root 2). But then it doesn't seem to connect with the [100] normal vector, which confuses me.
P.S. I have also derived that in silicon's crystal structure the atomic radius and lattice constant can be related by the equation r = (a(3)^0.5)/8 (read it as "a root 3 over 8"), but I don't get how this is relevant to the question, however the information was provided so I think it relates somehow.
Never mind, solved.
18K
  • · Replies 0 ·
10K
