| Thread Closed |
Taylor Polynomial Approximation of log(2.25) |
Share Thread |
| Mar24-10, 04:16 AM | #1 |
Determine the order two Taylor polynomial, p2(x, y), for f(x, y) = log e (1 + x2 + y4) about point (0, 1) ANSWER: loge (2) + 2y - 2 + [tex]\frac{1}{2}[/tex] [ x2 - 2y2 + 4y - 2 ] Managed that question and should be correct. If not, do let me know =) Part 2: Using p2 (x, y), find a quadratic approximation to log e (2.25) to 4 decimal places. Use a calculator to find the value of log e (2.25) to 4 decimal places, and comment on your answer. 2. Relevant equations 2nd Order Taylor Polynomial p2(x, y) = f(x, y) + (x + a)[tex]\frac{\partial f}{\partial x}[/tex] + (y + b)[tex]\frac{\partial f}{\partial y}[/tex] + [tex]\frac{1}{2}[/tex] [ (x - a)2[tex]\frac{\partial ^2 f}{\partial x^2}[/tex] + (x - a)(y - b)[tex]\frac{\partial ^2 f}{\partial x\partial y}[/tex] + (y - b)2[tex]\frac{\partial ^2 f}{\partial y ^2}[/tex] ] 3. The attempt at a solution I'm not too sure where to go from there...I thought of putting p2(x, y) as log 2 (2.25) but I'm not sure what that does after simplifying... Any assistance would be of much help! =) Thanks |
| Mar24-10, 07:10 AM | #2 |
Just choose values of x and y so that f(x,y)=log 2.25 and plug those values into your expansion. |
| Mar24-10, 08:29 AM | #3 |
I got fyy = -2
This was from fyy = [tex]\frac{12y^2( 1 + x^2 + y^4 ) - 16y^2}{(1 + x^2 + y^4 ) ^2}[/tex] and since at point (0,1), fyy = [tex]\frac{12 (1)^2( 1 + (0)^2 + (1)^4 ) - 16 (1)^2}{(1 + (0)^2 + (1)^4 ) ^2}[/tex] fyy = -2 Isn't it? Unless I stuffed up the Taylor polynomial part somewhere... Oh, when I meant putting p2(x, y) as log e (2.25) [correction], I meant like: loge(2.25) = loge (2) + 2y - 2 + [tex]\frac{1}{2}[/tex] [ x2 - 2y2 + 4y - 2 ] But yeah..got me no where =( I don't understand how I can choose values for x and y because how can we figure out what is loge (2.25) from something like loge (2) + constant. Seeing that we just choose values for x and y...unless there's the use of a calculator. Could you help shed some light on this? Thanks =) |
| Mar24-10, 09:16 AM | #4 |
Mentor
You have f(x, y) = ln (1 + x2 + y4),
so f(0, 1) = ln(1 + 02 + 12) = ln 2 You want ln 2.25, which can be represented as f(.5, 1). Use the polynomial you found to approximate f(.5, 1) by p2(.5, 1). |
| Mar24-10, 02:31 PM | #5 |
| Mar24-10, 05:28 PM | #6 |
Thanks a lot guys, I believe I managed to get it now. Worked it out to be loge (2) + [tex]\frac{1}{8}[/tex] = 0.8181 Hopefully that's right =) |
| Thread Closed |
Similar discussions for: Taylor Polynomial Approximation of log(2.25)
| Taylor polynomial approximation- Help! | Calculus | 4 | ||
| Really need help - Taylor Polynomial Approximation Error | Calculus & Beyond Homework | 2 | ||
| Taylor Polynomial Approximation | Calculus | 1 | ||
| Taylor polynomial approximation...(HELP ME) | Calculus & Beyond Homework | 3 | ||
| Taylor Approximation | Introductory Physics Homework | 2 | ||
