The discussion revolves around troubleshooting a PSpice simulation issue involving a schematic with a DC voltage source, resistor, and capacitor in series. Participants are exploring the expected output of the simulation and the reasons for obtaining a constant voltage reading instead of a transient response.
- Technical explanation, Debate/contested, Experimental/applied
- One participant reports that the simulation yields a straight line at 10V instead of a curve from 0 to 10V, indicating a potential issue with the setup.
- Another participant suggests that the issue may stem from performing a bias-point simulation instead of a transient simulation and recommends using a step source instead of a VDC source.
- A participant expresses confidence that they are conducting a transient simulation, as indicated in the simulation profile, and questions the necessity of using a step source over VDC.
- Another contributor notes that while DC is acceptable, the program might calculate the initial bias point, which could be the same as the final output, and suggests using a step DC or a switch with an appropriate time step.
- One participant agrees with the previous suggestion and emphasizes the importance of ensuring the time scale is small enough to capture the transient response accurately.
Participants express differing views on whether a step source is necessary and the implications of the time scale on the simulation results. The discussion remains unresolved regarding the best approach to achieve the expected transient response.
There are limitations regarding the assumptions about the simulation setup, the definitions of the sources used, and the time scale settings that may affect the output. Participants have not reached a consensus on the optimal configuration for the simulation.
