What is the combined speed of two rugby players after a tackle?
The combined speed of two rugby players after a tackle can be calculated using the conservation of momentum formula: m1*u1 + m2*u2 = (m1+m2)*V. In this scenario, a 120 kg player running south at 6 m/s and a 90 kg player running east at 8 m/s results in a combined speed of approximately 6.86 m/s after the tackle. It is crucial to treat the velocities as vectors and focus on the scalar speed rather than vector velocity in the final calculation.
  • Understanding of vector physics
  • Familiarity with momentum conservation principles
  • Basic knowledge of scalar vs. vector quantities
  • Ability to perform calculations involving mass and velocity
  • Study vector addition in physics
  • Learn about momentum conservation in collisions
  • Explore the differences between speed and velocity
  • Practice problems involving momentum calculations in sports scenarios
Physics students, sports scientists, coaches, and anyone interested in understanding the dynamics of player interactions in rugby and similar sports.
jazzchan
I have a problem as follows:
A rugby player, mass 120 kg is running due south at 6 m/s. He is tacked by an opponent, mass 90 kg, due east at 8 m/s. Calculate the combined speed of the joined players immediately after the tacke.
I assume that
m1*u1 + m2*u2 = (m1+m2)V
is it right ?
thanks
jazz
True enough, but remember:
1.There's no way but to treat the velocities as vectors here!
2. You are asked for the SPEED, rather than the VELOCITY, so your final answer should be a scalar(number), not a vector
Yes, your assumption is correct. To calculate the combined speed of the players after the tackle, you can use the conservation of momentum equation:
Where m1 and u1 are the mass and initial velocity of the first player (120 kg and 6 m/s, respectively) and m2 and u2 are the mass and initial velocity of the second player (90 kg and 8 m/s, respectively).
Plugging in the values, we get:
(120 kg)(6 m/s) + (90 kg)(8 m/s) = (120 kg + 90 kg)*V
720 kg*m/s + 720 kg*m/s = 210 kg*V
1440 kg*m/s = 210 kg*V
V = 6.86 m/s
Therefore, the combined speed of the players immediately after the tackle is approximately 6.86 m/s.
I hope this helps! If you have any further questions, please feel free to ask. Good luck with your calculations!
