Semi-classical quantum/Poisson Brackets
  • Context: Graduate
  • Thread starter Thread starter barnflakes
The discussion revolves around the calculation of the Poisson bracket \{L_n, L_m\} for n, m = 1, 2, 3, specifically focusing on the transition from one expression to another in the context of semi-classical quantum mechanics. It includes technical reasoning and mathematical exploration related to Poisson brackets.
  • One participant questions the lecturer's transition between two expressions involving Poisson brackets and seeks clarification on the underlying properties used.
  • Another participant asserts that only three non-zero Poisson brackets exist involving q and p, specifically \{q_1,p_1\} = \{q_2,p_2\} = \{q_3,p_3\} = 1, while all other brackets vanish.
  • A participant explains how to derive the Poisson bracket using the definition, emphasizing the zero brackets of certain terms in the expression.
  • One participant attempts to apply the definition of the Poisson bracket to compute specific terms but expresses confusion over the final result and its relation to the expected outcome.
  • A later reply corrects the misunderstanding regarding the vector nature of the derivatives in the Poisson bracket definition, providing a detailed calculation that leads to a different result.
Participants express differing levels of understanding regarding the application of Poisson brackets, with some providing corrections and clarifications. The discussion remains unresolved as participants explore various interpretations and calculations without reaching a consensus.
Participants highlight the importance of specific properties of Poisson brackets and the implications of using the definition correctly, indicating potential misunderstandings in the application of these concepts.
barnflakes
I'm trying to workout the poisson bracket [itex]\{L_n, L_m\}[/itex] n,m = 1,2,3.
In the answers, my lecturer has written [itex]\{L_1, L_2\} = \{q_2 p_3 - q_3 p_2 , q_3 p_1 - q_1 p_3\}[/itex] which of course I understand. Then the very next line he writes [itex]= q_2 \{p_3 , q_3\} p_1 + p_2 \{q_3, p_3\} q_1[/itex]
I don't quite see how he has jumped so quickly from one to the other. Has he missed several lines of calculations here, or is he using some property of the Poisson Bracket that I can't see?
Thank you
You only need the property that there are just three non-zero Poisson brackets involving q and p
[tex]\{q_1,p_1\} = \{q_2,p_2\} = \{q_3,p_3\} = 1[/tex]
All other brackets vanish. Then
[itex]\{L_1, L_2\} = \{q_2 p_3 - q_3 p_2 , q_3 p_1 - q_1 p_3\} =<br /> \{q_2 p_3, q_3 p_1\} - \{q_3 p_2 , q_3 p_1\} - \{q_2 p_3, q_1 p_3\} + \{q_3 p_2 , q_1 p_3\} = \{q_2 p_3, q_3 p_1\} + \{q_3 p_2 , q_1 p_3\}[/itex]
[itex]= q_2 \{p_3 , q_3\} p_1 + p_2 \{q_3, p_3\} q_1 = q_1 p_2 - q_2 p_1 = L_3[/itex]
Eugene.
Eugene.
Thanks Eugene, I'm a still confused exactly how you've used the [tex]\{q_1,p_1\} = \{q_2,p_2\} = \{q_3,p_3\} = 1[/tex] condition in this [tex]\{q_2 p_3, q_3 p_1\} - \{q_3 p_2 , q_3 p_1\} - \{q_2 p_3, q_1 p_3\} + \{q_3 p_2 , q_1 p_3\}[/tex] expression though? Could you be a bit more explicit? Sorry for the stupid questions, I have a feeling I really don't understand poisson brackets very well at all yet.
Take, for example, the second term
[tex]\{q_3 p_2 , q_3 p_1\}[/tex]
and consider the left part of the bracket [tex]q_3 p_2[/tex]. The first factor q3 has zero brackets with both factors on the right side (q3 and p1). The second factor p2 also has zero brackets with q3 and p1. Therefore, the product [tex]q_3 p_2[/tex] has zero bracket with the product [tex]q_3 p_1[/tex].
You can get this result also by the direct use of the Poisson bracket definition
[tex]\{f, g\} \equiv \frac{\partial f}{\partial \mathbf{q}} \cdot \frac{\partial g}{\partial \mathbf{p}} - \frac{\partial f}{\partial \mathbf{p}} \cdot \frac{\partial g}{\partial \mathbf{q}}[/tex]
Eugene.
In my preceding post I assumed the following identity
[tex]\{ab , c\} = a \{b , c\} + \{a , c\} b[/tex]
which can be proved for all a,b,c from the Poisson bracket definition.
Eugene.
Thanks again Eugene. It is clear you have a much more intuitive understand of poisson brackets than I do, so instead I have tried using the direction definition of the Poisson bracket.
If we take the first term:
[tex] \{q_2 p_3, q_3 p_1\}[/tex]
Then applying the above definition we have:
[tex](q_2 p_3)_p (q_3 p_1)_q - (q_2 p_3)_q (q_3 p_1)_p[/tex]
Where subscript p & q denote differentiation wrt that momentum & coordinate.
So considering just the very first term [tex](q_2 p_3)_p (q_3 p_1)_q[/tex] and using that definition I obtain:
[tex](\frac{\partial q_2}{\partial p_3} \cdot p_3 + \frac{\partial p_3}{\partial p_3} \cdot q_2)(\frac{\partial q_3}{\partial q_3} \cdot p_1 + \frac{\partial p_1}{\partial q_3}) \cdot q_3 = p_1 q_2[/tex]
Is this correct? If so, when I work out the entire expression, I obtain:
[tex]q_2 p_1 - p_3 q_3 - q_3 p_1 + p_2 q_3 -q_2 p_3 + p_3 q_1 + q_3 p_3 - p_2 q_1 = q_2 p_1 - q_3 p_1 + p_2 q_3 -q_2 p_3 + p_3 q_1 - p_2 q_1[/tex]
and I cannot see how that relates to the final answer?
This is not correct. In the definition of the Poisson bracket the derivative [tex]\partial f/\partial \mathbf{q}[/tex] means a 3-vector [tex](\partial f/\partial q_1, \partial f/\partial q_2, \partial f/\partial q_3)[/tex] and [tex]\partial f/\partial \mathbf{p} \equiv (\partial f/\partial p_1, \partial f/\partial p_2, \partial f/\partial p_3)[/tex]. Using this notation we obtain
[tex]\{q_2 p_3, q_3 p_1 \} = \left( \frac{\partial (q_2 p_3)}{\partial q_1 }, \frac{\partial (q_2 p_3)}{\partial q_2 }, \frac{\partial (q_2 p_3)}{\partial q_3} \right) \cdot \left( \frac{\partial (q_3 p_1)}{\partial p_1 }, \frac{\partial (q_3 p_1)}{\partial p_2 }, \frac{\partial( q_3 p_1)}{\partial p_3}\right) - \left( \frac{\partial (q_2 p_3)}{\partial p_1 }, \frac{\partial (q_2 p_3)}{\partial p_2 }, \frac{\partial (q_2 p_3)}{\partial p_3} \right) \cdot \left( \frac{\partial (q_3 p_1)}{\partial q_1 }, \frac{\partial (q_3 p_1)}{\partial q_2 }, \frac{\partial (q_3 p_1)}{\partial q_3} \right)[/tex]
[tex]= (0, p_3, 0) \cdot (q_3, 0, 0) - (0, 0, q_2) \cdot (0, 0, p_1) = -q_2p_1[/tex]
Eugene.
  • · Replies 88 ·
15K
11K
  • · Replies 21 ·
  • · Replies 34 ·
  • · Replies 18 ·
