Pathlength Difference from two waves
  • Thread starter Thread starter skibum143
    Difference Waves
The discussion centers on calculating the pathlength difference between two waves originating from slits separated by 0.12 mm, illuminated by a coherent light source with a wavelength of 549E-6 mm. The pathlength difference at the first maximum (m=1) is determined using the equation d*sin(theta) = m*wavelength, where the distance to the screen (D) is 780 mm. The participant successfully calculated the distance between the two maxima (y) as 0.0036 m and concluded that the pathlength difference is directly related to the order of the maximum (m) multiplied by the wavelength.
  • Understanding of wave interference principles
  • Familiarity with the double-slit experiment
  • Knowledge of trigonometric relationships in physics
  • Ability to manipulate equations involving wavelength and distance
  • Study the derivation of the double-slit interference formula
  • Learn about the significance of maxima and minima in wave patterns
  • Explore the effects of varying slit separation on interference patterns
  • Investigate the role of wavelength in determining interference outcomes
Students studying wave optics, physics educators, and anyone interested in understanding interference patterns in coherent light sources.
skibum143
Two slits separated by a distance of d = 0.12mm are located at a distance of D = 780mm from a screen. The screen is oriented parallel to the plane of the slits. The slits are illuminated by a coherent light source with a wavelength of lambda = 549E-6 mm. The interference pattern shows a peak at the center of the screen (m=0) and then alternating minima and maxima.
7. [1pt]
What is the pathlength difference between the two waves from the two slits at the first (m=1) maximum on the screen?
d*sintheta = m*wavelength
sintheta = y(dist bt two maxima) / D(distance to screen)
I'm really confused about what the "pathlength difference" refers to. It doesn't specify it in the book. I know the angles take different paths to get to the same point because of the distance inbetween them, but is it asking for an angle?
I solved the problem for y using the above equations, and at the first maxima (m=1), y(distance between the two maxima) is 0.0036m. But I don't know where to go from there?
So...I think I just realized that pathlength difference refers to "m", but what are the units??
Ah, just figured it out...you have to use "m" and multiply it by the wavelength.
11K
