Problem 4, Landau/Lifshitz, page 12
  • Thread starter Thread starter fluidistic
The problem involves analyzing the dynamics of a system of particles in a mechanics context, specifically focusing on the Lagrangian formulation. The original poster expresses confusion regarding the presence of a gravitational term in the solution provided in the textbook, despite their understanding that no gravitational field is mentioned in the problem statement.
  • The original poster attempts to derive the Lagrangian by calculating the kinetic energies of the particles involved, questioning the necessity of including gravitational effects. Other participants suggest that the mention of "vertical" implies the presence of a gravitational field and discuss the contributions to kinetic energy from changing angles.
Participants are actively questioning the assumptions made about the gravitational field and the definitions of the angles involved. There is a recognition of potential missing terms in the kinetic energy calculations, and some participants are clarifying their notation and understanding of the problem setup.
There is uncertainty regarding the specific definitions of angles used in different versions of the textbook, which may affect the interpretation of the problem. The discussion highlights the need for clarity on whether gravitational effects should be considered based on the problem's wording.
fluidistic
The problem can be found there, page 12, problem 4: http://books.google.com.ar/books?id...ntcover&dq=mechanics&cd=1#v=onepage&q&f=false.
[tex]\vec v = \vec \omega \wedge \vec r[/tex].
[tex]L=L_1+L_2+L_3[/tex].
I've made an attempt and then saw the solution given in the book and I don't get it. First, there is no mention of a gratitational field, hence why is there a "g" term in the solution?
My attempt: None of the 3 particles have potential energy, hence the Lagrangian is simply the sum of the kinetic energies of the particles.
For each one of the 2 particles [tex]m_1[/tex], I've found that [tex]T=\frac{m_1}{2} \Omega ^2 l^2 \sin ^2 (\phi)[/tex] since they describe a circular motion of radius [tex]l \sin \phi[/tex]. So it only remains to find the kinetic energy of [tex]m_2[/tex].
Choosing the origin at point A, [tex]x=2l \cos \phi[/tex]. Now to calculate [tex]\dot x[/tex], I think that only [tex]\phi[/tex] may vary thus [tex]\dot x = -2l \dot \phi \sin \phi[/tex]. So I get [tex]T_2=2m_2 l^2 \sin ^2 (\phi )[/tex].
Which gives me [tex]L=l^2 \sin ^2 (\phi) (m_1 \Omega ^2 +2 \dot \phi ^2 m_2)[/tex].
I wonder if my answer is correct if I assume no external gravitational field. L&L didn't specify the field but in the answer there's a "g"...
Thanks for any kind of help.
Usually whenever the word "vertical" is used in a mechanics problem, it's safe to assume there is an earth-like gravitational field [itex]g[/itex] present.
Even without a gravitational field present, wouldn't there be an additional contribution to the kinetic energy of each [itex]m_1[/itex] when [itex]\theta[/itex] is changing?
And your kinetic energy for [itex]m_2[/itex] makes no sense to me...did you mean [tex]T_2=2m_2 l^2\dot{\theta}^2\sin^2\theta[/tex]?
Edit: Maybe your version of the text uses different labels for the angles...in my version, [tex]\Omega=\dot{\phi}[/tex] and [itex]\theta[/itex] represents the angle the massless rods make with the axis of rotation.
Ok thanks a lot. I will remember this.
Hmm. Ok a (or 2?) term is missing. I think I've calculated the KE the masses have with their circular motion. It would remain the term of the vertical (and horizontal?) KE. Unless I'm misunderstanding something.
Yes I meant this, I made a typo error.
I see. So when you said "theta" in the upper question, which notation did you use?
Not a factor of 2, but a term involving [itex]\dot{\theta}[/itex], corresponding to the motion of each [itex]m_1[/itex] when the rotating frame is stretched or squished.
The one where theta is the angle the upper supports make with the axis of rotaion/
10K
  • · Replies 26 ·
