Intersecting yz-plane: x^2 + y^2 - 4 Curve
The discussion revolves around the surface defined by the equation z = x^2 + y^2 - 4 and its intersection with the yz-plane. Participants explore whether the surface intersects the yz-plane and the nature of the resulting curve.
  • Participants discuss the intersection of the surface with the yz-plane, questioning the points of intersection and the nature of the curve formed. Some express confusion about the number of intersection points and the implications of the surface's shape.
The discussion is ongoing, with participants offering insights into the nature of the surface and its intersections. There is a recognition of multiple interpretations regarding the intersection points and the curves involved, but no explicit consensus has been reached.
Some participants note the original problem's requirement to find intersections with multiple coordinate planes, leading to further exploration of the curves and their intersections with the axes. There is also mention of the symmetry of the surface and the implications for the intersections.
madachi
Does the surface [itex]z = x^2 + y^2 - 4[/itex] * intersects the [itex]yz[/itex]-plane? If so, find the equation of the curve and write down the points of intersection.
[itex]yz-[/itex]plane, so [itex]x=0[/itex]
1) * becomes [itex]z = y^2 - 4[/itex] and this is the equation of the curve that intersects the [itex]yz[/itex]-plane.
2) So the intersection points are [itex](0,-2,0)[/itex] and [itex](0,2,0)[/itex]
Are 1) and 2) correct? Thanks in advance!
Shouldn't there be a third intersection point?
You found the intersection points of the curve on the y-axis, what about the z-axis?
Is it [itex](0,0,-4)[/itex] ? But I am slightly confused, doesn't the whole curve intersect yz-plane and so there are infinitely many points of intersection?
Thanks.
the graph of [itex]z = x^2 + y^2 - 4[/itex], is a parabaloid, rotationally symmetric about the z axis
the intersection of the surface with the yz plane (x=0) is the parabola [itex]z = y^2 - 4[/itex] which has, as you say, infinitely many points.
I'm not too sure what the last part is asking for, maybe it is where the curve intersects the y & z axis...
I wanted to do the question myself so I only show a part of the question.
The original question is:
If the surface intersects the [itex]xy, xz[/itex], and [itex]yz[/itex] coordinate planes, find the equation of each of the parabolic boundary curves. Where do the curves intersect with the three coordinate axes?
I thought if the surface intersects the three coordinate planes, then the points of intersection must be [itex](0,0,0)[/itex]?
Thanks.
Thanks.
nope, that is not a point on the surface, and so none of the curves pass through that point
the easiest way to work out what i going on is to try & draw a picture, so i hope you'e attempted that. This problem is essentially showing you agood way to draw simple 3D surfaces, by drawing the intersection on each coordinate plane.
you should get 2 parabolas & and a circle
if you think about the shape of the surface and curves, the curve constrained by x = 0, will never intersect the x axis. So each point of intersection with axis will have 2 curves passing through it
due to the symmetry (which can save you some time) there will be one point of intersection on the z axis and 2 each for the x & y...
I have drawn the graph, it's a paraboloid. But I don't understand about the 2 parabolas and a circle.
I understand that the level curves are parabola and circle, but why the intersecting ones are only the specific 2 parabolas and 1 circle that you mentioned?
Thanks.
ok, so what is the equation for each curve...
[itex]z = x^2 - 4[/itex]
[itex]x^2 + y^2 = 4[/itex]
Are these correct?
yep so what do the forms of those equations look like?
The first two are parabolas. The last one is circle.
So are the intersection points
1) [itex](-2,0,0),(2,0,0)[/itex] for the first curve.
2) [itex](0,-2,0),(0,2,0)[/itex] for the second curve.
3) [itex](0,0,-4)[/itex] for the third curve mentioned above?
Thanks.
Thanks.
the points look ok, but they correspond to an axis, not a specific curve, each will have 2 curves passing through it
I am confused. Could you show me the equation for one the curves so I can try to figure what you mean? Didn't I already show the equation of the 3 curves? Are they different from the ones that you just mentioned? Thanks.
you've got it all, so pulling it together from your posts (though check it as i did pretty quick):
curve 1 - yz plane (x=0)
curve 2 - xz plane (y=0)
curve 3 - xy plane (z=0)
axes intersection points
x axis - (-2, 0, 0) and (2,0,0) by curves 2&3,
y axis - (0 ,-2, 0) and (0,2,0) by curves 3&1,
z axis - (0 , 0, 4) by curves 1&2
I see, thanks!
