Diamond Coating of Tungsten Carbide
The discussion revolves around the coating of tungsten carbide (WC) tools with diamond, specifically focusing on the deposition processes involved, the material properties of WC and its common alloying with cobalt (Co), and the challenges associated with diamond adhesion to these substrates.
  • Some participants inquire about the deposition processes used for coating WC tools, specifically mentioning chemical vapor deposition (CVD).
  • It is noted that WC is a suitable substrate for diamond coatings, and that extensive research has been conducted in this area, including the use of Hot Filament CVD.
  • Questions arise regarding the necessity of cobalt in WC tools, with some participants suggesting that WC can exist without Co and that alloying may be aimed at reducing brittleness.
  • Concerns are raised about the cobalt binder potentially inhibiting diamond adhesion, with suggestions for chemical pre-treatment to remove Co from the substrate surface before coating.
  • A participant shares a resource that discusses the properties of WC-Co as a cermet and its implications for coating.
  • One participant expresses gratitude for shared resources and reflects on the challenges faced in coating WC-Co tools, suggesting that surface pretreatment may help address these issues.
Participants express varying views on the necessity of cobalt in WC tools and its effects on coating processes. There is no consensus on whether WC can be effectively coated without Co or the best approach to enhance adhesion.
Participants mention limitations related to the brittleness of WC, the role of cobalt as a binder, and the potential need for surface pretreatment, but these aspects remain unresolved and contingent on specific conditions.
This discussion may be of interest to materials scientists, engineers involved in tool manufacturing, and researchers focused on coating technologies and wear-resistant materials.
engineer23
Does anyone have any expertise in the coating of WC tools? Are these tools coated by a deposition process (ex. CVD)?
WC (Hard tools) are good substrates for diamond coatings. The meet all the requirements for this sort of coatings. They are coated by a CVD process and loads of research has gone into this area.
Hot Filament CVD has been used. You can also look into the paper 'Interaction of hard metal substrates during diamond deposition' by R Haubner for more information.
Most papers I have found focus on coating a base material of WC-Co. Is WC always alloyed with Cobalt? It is possible to have a tool that is WC alone?
It seems that the alloying is done to make the material less brittle (and thus avoid fracture of tools in machining applications). I also understand from these articles that the Cobalt binder inhibits adhesion of diamond to the substrate. One article recommended a course of chemical pre-treatment to remove the Cobalt binder from the substrate surface. While using WC would make the tool more brittle, wouldn't it also make it easier to coat?
WC-Co is a cermet. WC is very brittle, and the Co is basically a more ductile binder.
This paper might be of interest
http://www.matmod.com/Publications/armor_1.pdf
There are probably other good papers, but it's a matter of finding them.
^Thank you. That paper is very helpful. I ordered some WC tools to be coated with diamond (in search of the ever-elusive wear resistant tooling). I'm guessing now that these are in fact WC-Co tools? That would explain the difficulty that the diamond lab has encountered in attempting to coat them using CVD tehcniques (this is their first foray into coating WC).
It seems like the surface pretreatment suggested in some of these papers to etch away the Co from the substrate surface may be a potential solution to our problem.
