Looking for an analytical solution for a quadratic attractive potential well
The discussion focuses on deriving the equation of motion for a charged particle in a quadratic attractive potential well, specifically an electron influenced by a fixed proton. The force acting on the particle is described by the equation kq1q2/x², leading to the second-order differential equation d²x/dt² = c/x². The participant seeks an analytical solution, noting the singularity at x=0 may result in a transcendental solution. A method is suggested involving the transformation x'' = x' dx'/dx to convert the equation into a first-order format, allowing for integration and eventual solution.
  • Understanding of classical mechanics and electrostatics
  • Familiarity with differential equations, specifically second-order equations
  • Knowledge of analytical methods for solving differential equations
  • Basic concepts of singularities in mathematical functions
  • Study methods for solving second-order differential equations
  • Learn about singularity behavior in differential equations
  • Explore the concept of transcendental solutions in mathematical physics
  • Investigate the application of the transformation technique x'' = x' dx'/dx in solving differential equations
Physicists, mathematicians, and engineering students interested in classical mechanics, particularly those working with electrostatic potentials and differential equations.
parsec
I am trying to derive an equation of motion for a simple electrostatic potential well.
Imagine a scenario where an electron (or other charged particle) is released from an arbitrary distance from a fixed (unperturbable) attractive charge (say a proton fixed in space).
In 1 dimension, the force on the particle should be kq1q2/x2
Which should yield the following second order differential equation of motion
d2x/dt2=c/x2
or x''-x-2=0
I can't seem to find an analytical solution to this equation. I'm told that due to the singularity at x=0 it will have a transcendental solution?
thanks
The trick to solving equations like this one, where the independent variable t is not present, is to write
x'' = x' dx'/dx. Then you have a first order equation involving x' and x. Collect terms in x' and x, then integrate both sides. Then solve for x', and integrate a second time. This will give you an analytic solution for this equation, although it will probably be more complicated than you like.
