What is the total force on a line charge due to another? Hw question
The total force on a line charge due to another parallel line charge can be calculated using the formula F = (Lλ)² / (a² 4πε). The linear charge density (λ) is constant, and the electric field (E) generated by one line charge must be integrated over the length of the other line charge. The setup requires two integrals: one for the electric field from the first wire and another for the force exerted on the second wire, accounting for the non-constant nature of the electric field along the wire's length.
  • Understanding of electric fields generated by line charges
  • Knowledge of Gauss's Law
  • Familiarity with integral calculus
  • Concept of linear charge density (λ)
  • Study the application of Gauss's Law for line charges
  • Learn about electric field calculations for finite line charges
  • Explore integral calculus techniques for evaluating electric fields
  • Review hyperphysics resources on electric fields and forces
Students in physics, particularly those studying electromagnetism, as well as educators looking for insights into teaching concepts related to electric forces and fields.
ProtonHarvest
Two line charges of the same length L are parallel to each other and located in the xy plane. They each have the same linear charge density λ=constant. Find the total force on II due
to I.
F =QE
Q = [tex]\lambda[/tex]L
E = ? This is where I'm stuck.
This got me a 0 points on the homework so I know its very wrong. I really just need some clues as to how to set up the integral, or if this is just some kind of trick question, what makes it tricky. I've got tunnel vision at this point so any help will be greatly appreciated.
[tex]d\vec{E} = \frac{\lambda dl \hat{r}}{4\pi\epsilon a^{2}}[/tex]
[tex]\vec{E} = \frac{1}{4\pi\epsilon}\int\frac{\lambda dl\hat{r}}{a^{2}}[/tex]
=[tex]\frac{L\lambda}{a^{2}4\pi\epsilon}[/tex]
[tex]\vec{F} = \frac{(L\lambda)^{2}}{a^{2}4\pi\epsilon}[/tex]
Use Gauss's law to find the electric field generated by an infinite line charge.
EDIT: Nevermind, just read they weren't infinite.
You will have 2 integrals. One for the electric field from wire 1 (and your setup for the E-field from wire doesn't look right at all, you need some z-dependence in it). You will also need a 2nd that runs over the 2nd wire summing up [itex]\lambda E_x(y_2) dy_2[/itex] to get the net force in the x-direction. This is because the electric field isn't constant over the length of the wire, so you can't just say F = E*Q.
Wouldn't the radial component be [tex]E_{x}[/tex], & depend only on y and x, since this is a strictly 2-dimensional problem?
Using the hyperphysics site and the setup you see in the picture, I got:
[tex]dE_{x} = \frac{\lambda xdy}{4\pi\epsilon r^{2}r}[/tex]
[tex]E_{x} = \frac{\lambda}{x4\pi\epsilon}\frac{L}{\sqrt{x^{2}+L^{2}}}[/tex]
Aside from that, thank you so much for the input, you broke my tunnel vision! I can see what to do now in principle and its very helpful. :smile:
  • · Replies 16 ·
