| Thread Closed |
Very basic coordinate problem |
Share Thread | Thread Tools |
| May23-10, 07:37 PM | #1 |
When you have a point in [tex]\Re[/tex]3, like for example let J(3, 7, 3) and Q(1, 2, 3). What is the distance in terms of coordinate between them? Like can you just subtract the corresponding components? 2. Relevant equations I am not sure if it only works for the formula distance formula. 3. The attempt at a solution Like what I meant was if I should try subtracting from J to Q to find (...) J - Q = (2, 5, 0) Does that work? Thank you |
| May23-10, 08:00 PM | #2 |
J-Q is the vector from Q to J. The distance between Q and J is the magnitude of J-Q, which is sqrt(2^2 + 5^2 + 0^2)
| May23-10, 08:07 PM | #3 |
| May23-10, 09:27 PM | #4 |
Yes, in order to get the displacement vector, you can just subtract components element by element. This makes sense if you think about J and Q as vectors from the origin and the displacement vector going from the head of J to the tail of Q. To find the distance, as mentioned above, you need to get the length of that vector. This procedure turns out to be equivalent to the distance formula.
| May23-10, 09:46 PM | #5 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Very basic coordinate problem
| Coordinate transformation and choice of a suitable coordinate system. | Special & General Relativity | 2 | ||
| Coordinate Problem | Introductory Physics Homework | 6 | ||
| 3-D Coordinate Problem. | Calculus & Beyond Homework | 1 | ||
| Help with coordinate problem | General Math | 1 | ||
| coordinate problem | Introductory Physics Homework | 4 | ||
