Will a PRV operate at zero-flow condition?
  • Thread starter Thread starter Mustafa Adada
    Condition
The discussion centers on the operation of Pressure Reducing Valves (PRVs) in a potable water transmission line designed to convey water over a 230Km distance with a diameter of 500mm. The hydraulic design considers the impact of static water pressure, which can reach 55 bars due to a 550m elevation difference. It is established that PRVs will operate effectively at zero-flow conditions, maintaining the set pressure regardless of flow rate. Alternatives to PRVs were also considered, but none were deemed necessary as PRVs fulfill the operational requirements.
  • Understanding of hydraulic design principles
  • Knowledge of Pressure Reducing Valves (PRVs)
  • Familiarity with potable water transmission systems
  • Basic concepts of static water pressure and elevation effects
  • Research the specifications and operational limits of various PRVs
  • Explore alternative valve types for zero-flow conditions
  • Study hydraulic design calculations for long-distance water transmission
  • Investigate maintenance protocols for potable water systems
Hydraulic engineers, water resource managers, and professionals involved in the design and maintenance of potable water transmission systems.
Mustafa Adada
I am working on a project that involves the hydraulic design of a potable water transmission line (diameter 500mm), that conveys water from the source location of elevation 1500m to the end point at an elevation of 950m. The hydraulic design requires several PRVs along the path (around 230Km long), but we are currently considering the following operational issue: in the event of maintenance and the necessity to shut down the pipe, will the PRVs continue to operate at zero-flow condition? Or will the static water pressure within the pipe reach 55bars (due to difference of elevation between the supply and end point)? If the PRVs do not operate at zero-flow, is there a different type of valve that provides a solution to this problem?
Yes, the RV's will operate at the given set pressure regardless of flow rate.
  • · Replies 53 ·
  • · Replies 31 ·
