Finding a plane parallel to a line, knowing a point on the plane
The discussion centers on finding the equation of a plane parallel to the line defined by the equations x - y + z = 1 and y + 5z = 0, which passes through the origin. Participants conclude that there are infinitely many planes that can satisfy these conditions, as any plane containing a line parallel to the given line can be formed. The direction vector of the line is determined to be (-6, -5, 1), and the normal vector of the plane must be perpendicular to this direction vector, leading to the general form of the plane equation Ax + By + (6A + 5B)z = 0.
  • Understanding of vector algebra and cross products
  • Familiarity with plane equations in three-dimensional space
  • Knowledge of parametric equations of lines
  • Concept of normal vectors and their relationship to planes
  • Study the derivation of parametric equations for lines in 3D space
  • Learn about the geometric interpretation of normal vectors in relation to planes
  • Explore the concept of infinite planes parallel to a line through various examples
  • Investigate the implications of linear independence in vector spaces
Students and professionals in mathematics, particularly those studying geometry and linear algebra, as well as anyone interested in understanding the properties of planes and lines in three-dimensional space.
Telemachus
Hi there, I got this problem to solve:
Given L:[tex]\begin{Bmatrix} x-y+z=1 & \mbox{ }& \\y+5z=0 & \mbox{ }& \end{matrix}[/tex], find the equation of the plane parallel to L that pass through the origin. Is it unic?
Well, I think its unic, cause there are not two different planes parallel to a line that pass through P(0,0,0).
I've started finding the director of L, [tex]\vec{d_L}[/tex] let's call:
[tex]\pi:x-y+z=1[/tex] [tex]\pi':y+5z=0[/tex]
[tex](1,-1,1)\wedge{(0,1,5)}=(-6,-5,1)=\vec{d_L}[/tex]
Lets call the plane [tex]\gamma[/tex], and [tex]\vec{n_{\gamma}}=(x_0,y_0,z_0)[/tex] a normal vector of [tex]\gamma[/tex]
[tex]<\vec{n_{\gamma}},\vec{d_L}>=0\Rightarrow{-6x_0-5y_0+z_0=0}[/tex]
[tex]\gamma:-6x-5y+z=0[/tex], [tex]P(0,0,0)\in{\gamma}[/tex]
So, that result is wrong, cause then [tex]\vec{n_{\gamma}}=d_L[/tex]
How should I continue? I know that I should find a vector normal to L, and normal to [tex]\gamma[/tex], but I don't know how to proceed. Cause, for L I can find infinite normal vectors. Now I'm starting to think that the answer is not unique.
? There are, in fact, an infinite number of different planes, parallel to a given line, through the origin! Draw the unique line through the origin that is parallel to the given line. Any plane that contains that line and not the original line satisfies the conditions.
Okay, another way to do that is to write the line as parametric equations. Using, say, z as parameter, we can write the second equation y= -5z. Then the first equation becomes x- (-5z)+ z= x+ 6z= 1 so that x= 1- 6z. That is the parametric equations are x= 1- 6t, y= -5t, z= t so the "direction vector" is (-6, -5, 1), just as you say.
Any plane through the origin can be written in the form Ax+ By+ Cz= 0. It will be parallel to the given line as long as its normal vector, (A, B, C), is perpendicular to the direction vector, (-6, -5, 1). That is, we must have -6A- 5B+ C= 0. That gives C= 6A+ 5B so that any plane Ax+ By+ (6A+ 5B)z= 0 satisfies the conditions.
Thank you very much.
Sorry for the misspelling :P
Bye there!
  • · Replies 18 ·
