Comparison Test Question: How to Determine Convergence of a Complex Integral?
The discussion focuses on determining the convergence of the integral \(\int_{3}^{\infty } \frac{1}{x + e^x} \,dx\). The user establishes that \(\frac{1}{x + e^x} < \frac{1}{e^x}\) and demonstrates that the integral of \(\frac{1}{e^x}\) converges to \(\frac{1}{e^3}\). The key conclusion is that since \(\frac{1}{x + e^x}\) has less area under its curve compared to \(\frac{1}{e^x}\), it also converges. The user clarifies that knowing \(\frac{1}{x}\) diverges does not imply that \(\frac{1}{x + e^x}\) diverges, as the latter has a smaller area under its curve.
  • Understanding of improper integrals
  • Familiarity with convergence tests for integrals
  • Knowledge of exponential functions and their properties
  • Basic graphing skills to visualize areas under curves
  • Study the comparison test for improper integrals
  • Learn about the behavior of exponential decay in integrals
  • Explore the properties of \(\frac{1}{x^p}\) for different values of \(p\)
  • Investigate other convergence tests, such as the limit comparison test
Students studying calculus, particularly those focusing on improper integrals and convergence analysis, as well as educators seeking to clarify these concepts for their students.
sponsoredwalk
I'm just curious as to how to think about the following form of equation.
[tex]\int_{3}^{\infty } \frac{1}{x + e^x} \,dx[/tex]
What you're trying to do is to test it;
[tex]\frac{1}{x \ + \ e^x} \ < \ \frac{1}{x}[/tex]
[tex]\frac{1}{x}[/tex] diverges
[tex]\frac{1}{x \ + \ e^x} \ < \ \frac{1}{e^x}[/tex]
[tex]\lim_{t \to \infty} \int_{3}^{t} e^{-x}\,dx \ = \ \lim_{t \to \infty} - e^{-x} | \ _3 ^t \ = \ \lim_{t \to \infty} - {\frac{1}{e^t} \ + \ \frac{1}{e^3}[/tex]
so this converges to [tex]\frac{1}{e^3}[/tex].
I don't get how this means the original eq. will also converge?
Both [tex]\frac{1}{x}[/tex] and [tex]\frac{1}{e^x}[/tex] are bigger than the original eq. with one converging and the other diverging.
[tex]\frac{1}{x}[/tex] is bigger than [tex]\frac{1}{e^x}[/tex] but the test of [tex]\frac{1}{x^p}[/tex] is ringing in my ears as a kind of explanation, but I am confused.
Is there an easy way to link all of this together?
Indeed, because for [strike]positive x[/strike] x > 1 when p > 1, 1/xp is always less than 1/x. In effect, its graph has less area underneath it for the integration. So there is no contradiction that 1/x leaves just too much area, i.e. it diverges, while 1/xp for p > 1 does not, i.e. it converges. Meanwhile, 1/ex just hugs the x-axis massively more than 1/xp for any constant p, hence it of course converges. Finally, 1/(x+ex) lies even closer to the x-axis and leaves even less area; it converges.
Knowing 1/x diverges does not mean we know 1/(x+ex) diverges or converges. The graph of the latter has less area, but by how much? Enough to stop the integral from diverging? However, knowing that 1/ex converges does tell us that 1/(x+ex) converges, since it has less area than a finite amount.
EDIT: It occurred to me that I also need x > 1, not just x positive. Sorry for the mistake.
Ahh Brilliant!
I think that idea of hugging the x-axis makes everything even clearer, thanks a lot for that :wink:
