Density of H20 @ 150 C & 600 psi
  • Thread starter Thread starter abhipatel
    Density Psi
The discussion revolves around the density of water (H2O) at a temperature of 150°C and a pressure of 600 psi. Participants explore the relationship between temperature, pressure, and density, particularly in the context of water as a two-phase system involving steam.
  • One participant seeks clarification on how to find the density of water at the specified conditions and questions the relationship between density, pressure, and temperature.
  • Another participant suggests that water can be considered incompressible unless very accurate data is required, referencing steam tables for relevant values.
  • A different participant emphasizes the need for steam tables, noting that the conditions described represent a two-phase system of water and dry steam.
  • Some participants express confusion over the use of mixed units (metric and imperial) in the original question.
Participants generally agree that water can be treated as incompressible for practical purposes unless high accuracy is needed. However, there is no consensus on the exact density values or the appropriate resources to find them, indicating multiple competing views remain.
The discussion highlights the need for specific steam tables to accurately determine the density of water under the given conditions, as well as the implications of considering water as a two-phase system.
abhipatel
Can anyone please show me how to look up Density of H20 @ 150 C & 600 psi pressure (Co2)...
I found a water table which shows 916.69 kg/m^3 but it does not show anything @ pressure. Isnt density related to both pressure & temp.?
What would be the difference in density if No gas was there and is gas was there?
Chemistry news on Phys.org
Unless you need some very accurate data you may safely assume water is incompressible. If my tables don't fail me and I read them correctly, at 150 deg C pressure of water vapor is around 5 atm.
This question really belongs in the mechancial engineering section.
You need a set of steam tables as the substance you are referring to is water at 600psi and 150 degC is a two phase system of water and dry steam.
I'm sorry I don't have these values covered in my available tables tonight.
Why the mixed units metric and imperial by the way?
No. Have you read my post? I have specifically addressed this problem - not directly, but precisely enough.
  • · Replies 17 ·
  • · Replies 67 ·
  • · Replies 0 ·
