So I've been confused about transformers lately. In searching for some
  • Context: Undergrad
  • Thread starter Thread starter Sferics
    Confused Transformers
The discussion revolves around the principles of transformers, specifically focusing on the relationship between voltage, current, and load in transformer circuits. Participants explore the implications of a step-up transformer on current and voltage, while addressing confusion regarding the definitions and roles of load and resistance in these systems.
  • One participant expresses confusion about how an increase in voltage in a step-up transformer should affect current in the secondary loop, questioning the energy conservation logic that suggests an increase in voltage results in lower current.
  • Another participant clarifies that the current in the secondary coil is influenced by the load, specifically a resistor, and explains the relationship between the currents in the primary and secondary coils, noting that while secondary current increases with voltage, the primary current increases even more.
  • A participant seeks clarification on the term "load," questioning whether it refers to the internal resistance of the generator or something else.
  • Another participant defines the load as the resistor connected to the secondary coil and explains the derivation of the current relationship based on power conservation.
  • A participant challenges the definition of load, suggesting that it is not just the resistor and expresses a desire to avoid using energy conservation as a basis for deriving equations.
  • One participant describes a circuit setup involving a transformer, generator, and resistor, indicating that they are assuming zero resistance in the generator and transformer while focusing on how current changes from the generator to the resistor.
  • A participant reiterates their circuit setup and asks if there is a method to derive the current relationship equation without relying on energy conservation, indicating ongoing confusion with the concept.
Participants do not reach a consensus on the definitions and implications of load versus resistance, and there remains uncertainty regarding the derivation of certain equations without invoking energy conservation principles. Multiple competing views on these concepts persist throughout the discussion.
Participants express varying assumptions about the roles of load and resistance in transformer circuits, and there are unresolved questions regarding the derivation of equations related to current and voltage relationships.
Sferics
So I've been confused about transformers lately. In searching for some information regarding the basic transformer, I came across this: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/transf.html#c1. While this page was informative, I am still left confused in regards to one point in particular.
Assuming the two windings are not touching and are simply magnetically coupled, shouldn't the current in the secondary loop be given by the induced voltage divided by the resistance in the loop? Thus, an increase in voltage, such as in a step-up transformer, should generate a larger current in the secondary loop. This line of reasoning, however, comes into conflict with the link's energy conservation logic, which claims that an increase in voltage should result in a lower current in the secondary loop. I see the validity in their reasoning, but I fail to see the flaw in mine.
I would greatly appreciate any and all help. Thanks in advance.
It's not resistance in the loop you have to worry about, it's the load.
Lets say you have a generator attached to your first loop applying some voltage V1 to the first coil. That induces voltage V2 on the second coil. Now, let's say that this second coil is attached to resistor R. The current in second coil, I2 is just V2/R. Does increasing V2 increase that current? Of course. But we should be comparing it to the current in first coil, I1. And that current works out to be I1 = V22/(V1R). So while current in second coil increases with increase in V2, the current in first coil increases even more, and regardless of the two voltages I1/I2 = V2/V1. So when transformer steps up voltage, it steps down current by the same ratio.
All of the above assumes no resistance in coils. With real transformer, you have to factors these in, but qualitative results are the same.
I'm sorry if this is an elementary question, but could you define load for me? What exactly is the load in this situation? The internal resistance of the generator...?
Additionally, I see how you can derive I1/I2 = V2/V1 from I1 = V22/(V1R) by substituting I2 = V2/R. But how did you get I1 = V22/(V1R)?
The load is the resistor (usually) furthest away from the generator for a simple case like this.
The equation comes from equating the input power I1*V1 to the output power V2^2/R.
Well, K^2's post begins by saying that I must worry about the load, not the resistor. But by using your logic, the load is the resistor in the second loop. Could you clarify what the load actually is in this example?
Also, while I understand your argument, I would like to stay away from energy conservation as a solution, seeing as I could have simply jumped straight to the equation I wanted to derive using that method.
Thanks in advance.
EDIT: What I mean by my second statement, is that if I substitute V2 = I2R in that equation, then I simply arrive at equation I wanted by energy conservation methods, which I already knew to be a valid method.
I'm considering a circuit like this Σ===3||ε===(~).
So you have a resistor, transformer, and the generator. Resistance in generator and transformer are assumed to be zero. Resistor is the sole load.
In general, the load might have complex impedance, but I'm ignoring all the subtleties in this example. Just showing how the current changes from generator to resistor.
Is there method to arrive at the equation I1 = V22/(V1R) excluding energy conservation (due to reasons outlined above) ?
Thanks for being patient with me. I am just having a hard time with this concept.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 26 ·
10K
  • · Replies 25 ·
