Calculate Drift Tube Length & Size for Accelerators
  • Context: Graduate
  • Thread starter Thread starter AllHailOdin
    Drift Formula Tube
The discussion revolves around the calculation of the length, size, and spacing of drift tubes used in linear accelerators (LINACs), as well as the frequency at which these tubes are driven. Participants explore the relationship between RF frequency and drift tube dimensions, focusing on both theoretical and practical aspects of LINAC design.
  • Some participants propose that the lengths of drift tubes are dependent on the RF frequency used for acceleration, suggesting that they must be progressively longer as the ion stream accelerates.
  • One participant presents a formula relating the distance between drift tube gaps to RF frequency, indicating that the spacing is given by ½ ν /c · c/f ≡ ½ β λ.
  • Another participant questions the implications of frequency on tube length, suggesting that higher frequencies could allow for shorter tubes, while also noting that the diameter of the tubes may not significantly impact performance.
  • A later reply introduces the distinction between electrostatic Wideroe linear accelerators and Alvarez drift tube linacs, explaining that the latter uses grounded drift tubes in a resonant RF field, which affects the spacing formula.
  • Participants express uncertainty about the meanings of certain symbols in the formulas, particularly regarding voltage, current, and the notation in the second half of the equation.
Participants generally agree on the dependence of drift tube dimensions on RF frequency, but there are competing views regarding the implications of this relationship and the specifics of the formulas involved. The discussion remains unresolved on several technical details and interpretations.
Participants note the distinction between different types of linear accelerators and their respective designs, indicating that assumptions about tube dimensions may vary based on the specific accelerator type being discussed. There are also unresolved questions regarding the meanings of certain variables in the formulas presented.
AllHailOdin
I was wondering if anyone knew the formulas uses to calculate the length and size and spacings of the drift tubes used in accelerators, and the formula used to calculate the frequency the tube is driven at.
Edit, looks like I put this in the wrong section, hopefully someone can move it.
Hi AllHailOdin! Welcome to PF!
The lengths of the drift tubes in a LINAC are a function of the RF frequency being used to accelerate the ions. They (the tubes) shield the ions inside for one-half of each cycle of the field and must therefore be made progressively longer as the plasma stream is accelerated.
The ion stream is accelerated in the gaps between drift tubes and the distance from the midpoint of one gap to the midpoint of the next gap is given by;
A good general history of linacs is here:
http://www.accsys.com/about/history.html
A more mathematical treatment of linac design is contained in lecture notes (.pdf's) from "Linear Accelerators: Theory and Practical Applications R.Jones" on this page;
http://www.cockcroft.ac.uk/education/academic0607.html
So if the tubes act as a faraday cage for 1/2 the frequency cycle, then that would mean the higher the frequency the shorter you can make the tubes ? But as the ion accelerates faster the tubes have to get progressively longer. So the diameter of the tubes don't matter much ?
so
v = Voltage in Volts ?
c = ? Current in Amps maybe ?
f = Frequency in Hertz ?
and I don't recognize the symbols of the second half (≡ ½ β λ).
so
The above formula is correct for the "electrostatic" Wideroe linear accelerator, where the rf voltage is applied directly to alternate drift tubes. Modern (Alvarez) drift tube linacs (DTLs) are standing wave linacs with grounded drift tubes in a large tank with a resonant longitudinal RF field. In this case the spacing between gaps is Ln = βnλ. Here, the velocity of the particle at the nth drift tube is v = βnc, and the rf frequency is f = c/λ. See page 22 of
http://www.cockcroft.ac.uk/education/PG_courses_2006-7/RJ_linacs_2007/Linacs_Week_1-Vers2.1.pdf
The Alvarez DTLs often have 50 or more drift tubes in a single tank. Each grounded drift tube has a focusing or defocusing magnetic quadrupole inside.
Bob S
  • · Replies 44 ·
