Chemical Kinetics: Rate Laws, Orders
The discussion focuses on determining the order of a chemical reaction using experimental data in chemical kinetics. Participants describe the process of calculating reaction order by comparing initial rates from different experiments, specifically using the ratio of concentrations and rates. A key example illustrates how dividing the results from two experiments can yield different orders, leading to confusion about which experimental pairs to use. The conversation emphasizes the importance of selecting appropriate experiments to achieve consistent and accurate results in determining reaction orders.
  • Understanding of chemical kinetics principles
  • Familiarity with rate laws and reaction orders
  • Ability to perform calculations involving ratios and exponents
  • Knowledge of experimental design in chemistry
  • Study the derivation of rate laws in chemical kinetics
  • Learn how to analyze reaction mechanisms and their impact on rate laws
  • Explore the use of integrated rate laws for different reaction orders
  • Investigate the significance of experimental design in obtaining reliable kinetic data
Chemistry students, educators, and researchers interested in mastering chemical kinetics and accurately determining reaction orders through experimental data analysis.
Whalstib
I understand how to determine the order of a rxn based on a series of experiments one divides one into another to obtain a ratio and then determines the power to which one is raised to determine the order.
Typical data collected would be:
Ex1 [A] .2 mol = Initial rate 4.8 mol/L*s
Ex2 [A] .4 mol = Initial rate 9.6 mol/L*s
etc...
In this case one would divide Ex2/Ex1 and obtain 2 = 2^m ; m=1 a 1st order rxn.
In our book every example has ex2/ex1 or ex4/ex3 but then in the problems in the back it takes what ever pair of experiments give a round number. Often this is obvious, often not and one would have to run a series of ex/ex to obtain an order..
A series I just started working on looked like ex2/ex1 would yield a nice even first order rxn but ended up being a .666 = .444^m; m=.5. The answer key chose a different pair of ex. and gives a m=2 2nd order rxn...
I have no attempt as my question is with a series of experiments giving different answers how does one know which answer to go with? Are only whole numbers desired? Why wouldn't any set of 2 experiments yield the same ratio or at least very close, with all things being equal?
Thanks,
Warren
I am not sure if I follow. Partially because it is not clear what you mean. What ex is - example? experiment? You can't divide example by example, you can divide reaction speeds.
Please show details of the question you mentioned where answer key selects different pair of "ex".
methods
14K
