HELP 3 physics problems that i am stuck on
This discussion addresses three physics problems related to kinematics and gravitational acceleration. The first problem involves calculating the average acceleration of a bullet penetrating a tree, where the correct approach utilizes the equation vf^2 = vi^2 + 2ad. The second problem requires determining the time for a ball thrown upwards at 36 m/s to return to its starting position, using the equation s(t) = v_0 t + 1/2 a t^2. The third problem focuses on finding the gravitational acceleration on a new planet based on the astronaut's jump height and speed, employing the formula y_max = v_0^2 / (2a).
  • Understanding of kinematic equations in physics
  • Familiarity with concepts of acceleration and gravitational force
  • Knowledge of energy conservation principles
  • Ability to manipulate algebraic equations
  • Study the derivation and application of kinematic equations
  • Learn about energy conservation in collisions and its implications
  • Explore gravitational acceleration calculations on different celestial bodies
  • Practice solving problems involving projectile motion and free fall
Students in college-level physics courses, educators teaching kinematics, and anyone seeking to improve their problem-solving skills in physics.
SJC25
HELP! 3 physics problems that i am stuck on
Help me out guys. I am in a college physics class and a week and a half into the class i am stuck.
1.) A bullet is moving at 244m/s. It hits a tree and penetrates 8.34mm. (A)What is the average acceleration as it slows? (B) Assuming constant acceleration, how long does it take for the bullet to stop.
I keep coming up with over 7mill m/s for part A... so obviously I am doing something wrong. If someone can just get me started on the right track I think I can figure the rest out.
2.) A ball is thrown straight up at 36m/s How long will it take for the ball to return to it's starting position?
I know it is one of the free fall equations, but i just can't figure out which... also, air resistance is not a factor.
3.) An astronaut lands on a strange, new planet. She discovers she can jump a maximum of 27m @ 6.0m/s. What is the magnitude of acceleration of gravity on the new planet?
Any help on any of these would be greatly appreciated. Thanks.
Stacy in NC
my note: use vf^2 = vi^2 + 2ad
you shouldn't get 7mil m/s. Try again.
my note: figure out the time it takes for an object to reach 36m/s with only gravitational acceleration. Then multiply it by 2 since the trajectory is symmetrical.
use vf = vi + at
my note: again use vf^2 = vi^2 + 2ad
Stacy in NC
P.S - just do more studying and you should do fine...
1) The kinetic energy of the bullet is
[tex]E = \frac{1}{2} m v_0^2[/tex]
The tree has to dissipate all of this energy by applying a force to the bullet. The relationship between work, force, and distance is
[tex]W = \mathbf F \cdot \mathbf d[/tex]
In this case, you know how much work is done (E) and the distance it was done over (d), and you can solve for F. You're not so much interested in the force as you are in the acceleration, so you can use Newton's second law to replace F with ma:
[tex]\frac{1}{2} m v_0^2 = Fd = mad[/tex]
The m's cancel, and you're left with a simple expression for the acceleration. This acceleration is in the millions of m/s2. This makes sense, when you realize that a bullet initially traveling at 244 m/s would cover 8.34 mm in about 34 millionths of a second:
http://www.google.com/search?hl=en&lr=&ie=UTF-8&q=8.34+mm+/+244+m/s&btnG=Search
The acceleration has to be quite large.
To find the time it takes the bullet to stop, just using the standard kinematic formula:
[tex]s(t) = v_0 t + \frac{1}{2} a t^2[/tex]
Where s(t) is the position of the bullet at time t. Plug in 8.34 mm for s(t), 244 m/s for [itex]v_0[/itex], and the acceleration you found above, then solve for time. The answer you get should be a few tens of microseconds.
2) If you're going to memorize any equations, memorize this one:
[tex]s(t) = v_0 t + 1/2 a t^2[/tex]
That's all you need to solve this problem. The acceleration is just g, and you know v_0. If the ball starts at ground level, then s(t=0) is 0. Solve this equation for the other permissible value of t.
3) You can derive the maximum height of a trajectory easily enough, but here's the formula:
[tex]y_\textrm{max} = \frac{v_0^2}{2a}[/tex]
Plug in the numbers and solve for a.
- Warren
  • · Replies 19 ·
