Alternating Current 6: Period, Load Resistance, RMS & Peak Power
  • Thread starter Thread starter islandguy
    Current
The discussion focuses on the characteristics of pure alternating current produced by an alternator, specifically analyzing the output voltage described by the equation V=12sin100t. The period of the alternating voltage is determined to be 0.01 seconds. The current through a resistive load of 6 ohms is expressed as I=(12sin100t)/6, leading to an r.m.s value of 0.2 amps. The peak power consumed by the load is calculated to be 0.24 watts.
  • Understanding of alternating current principles
  • Familiarity with Ohm's Law
  • Knowledge of root mean square (r.m.s) calculations
  • Ability to interpret sine wave graphs
  • Study the derivation of r.m.s values for AC circuits
  • Learn about power factor in AC circuits
  • Explore the concept of impedance in AC circuits
  • Investigate the behavior of AC circuits with different load types
Electrical engineers, physics students, and anyone involved in the analysis of alternating current systems will benefit from this discussion.
islandguy
6. A pure alternating current is produced by an alternator in which a coil rotates in a uniform magnetic field. The output voltage from the alternator can be described by V=12sin100t.
a) What is the period of the alternating voltage produced?
[ marks]
b) The output from the alternator is connected across a resistive Load of 6 ohms.
i) Write down the equation that describes the variation of current
through the load.
[ mark]
ii) Calculate the r.m.s value of the current.
[ mark]
iii) Calculate the peak value of the power consumed by the load.
[ mark]
iv) Sketch a graph of power developed across the resistor, as time passes.
Thanks for ur help
This is a plug-n-chug type of question. What kind of problem are you having with it?
a) The period of the alternating voltage produced is 1/100 seconds or 0.01 seconds.
b) i) The equation that describes the variation of current through the load is I=V/R, where V is the voltage and R is the resistance. In this case, the voltage is given by V=12sin100t, so the current can be written as I=(12sin100t)/6.
ii) To calculate the r.m.s value of the current, we need to square the current equation and then take the average over one period. This can be written as:
Irms = √(∫(I^2)dt/T)
= √(∫((12sin100t)/6)^2dt/T)
= √(∫(12^2sin^2(100t))/36dt/T)
= √((12^2/36)∫sin^2(100t)dt/T)
= √((12^2/36)(T/2))
= √((12^2/36)(1/200))
= √(12^2/7200)
= √(144/7200)
= 0.2 amps
Therefore, the r.m.s value of the current is 0.2 amps.
iii) To calculate the peak value of the power consumed by the load, we need to use the equation P=I^2R, where I is the r.m.s current calculated in part (ii) and R is the resistance. In this case, the peak power can be written as:
Ppeak = (0.2)^2 x 6 = 0.24 watts
Therefore, the peak value of the power consumed by the load is 0.24 watts.
iv) The graph of power developed across the resistor as time passes would look like a sine wave, with the peak power occurring at the peaks of the sine wave and the lowest power occurring at the zero crossings. The x-axis would represent time (in seconds) and the y-axis would represent power (in watts). The graph would look something like this:
[Graph of power developed across the resistor, with time on the x-axis and power on the y-axis, showing a sine wave with peaks at the top and bottom and zero crossings in between]
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 19 ·
