How Do You Determine Quantum Numbers from Hydrogen Atom Wavelengths?
  • Thread starter Thread starter Ush
    Wavelength
The discussion revolves around determining quantum numbers for a hydrogen atom based on emitted wavelengths. Participants are analyzing the relationship between energy levels and the wavelengths of light emitted during electron transitions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the use of energy equations related to quantum numbers and question the correct formulation of these equations. There is discussion about the implications of the restriction m > n and how it affects the energy calculations. Some participants express confusion about the signs of energy and the relationship between m and n values.
The discussion is ongoing with various interpretations being explored. Some participants have provided clarifications on the equations used, while others are attempting to reconcile their understanding of the quantum number relationships. There is no explicit consensus, but guidance has been offered regarding the correct application of energy equations.
Participants are working under the constraints of the problem statement, which includes two wavelengths and the requirement to find corresponding quantum numbers. There is an acknowledgment of potential confusion introduced by the problem's structure.
Ush
Two of the wavelengths emitted by a hydrogen atom are 9.50×10-8 m and 4.65×10-6 m. What are the m and n values for the first wavelength?
E = -13.6eV/n2
E = -13.6eV/(m2 - n2)
restriction:m > n
E = hf
f = c/λ
1 eV = 1.6 x 10-19J
hc/λ = -13.6eV/(m2 - n2)
hc/λ(-13.6eV) = 1/(m2 - n2)
λ(-13.6eV)/hc = m2 - n2
λ(2.179E-18J)/hc = m2 - n2
let λ =9.50×10-8
(9.50×10-8)(2.179E-18J)/hc = m2 - n2
1 = m2 - n2
1 = (m-n)(m+n)
...now what? o_o
...am I doing this right?
...if I do the same process with the other wavelength then I get
51 = mb2 - nb2
51 = (mb-nb)(mb+nb)
...but nothing says m and mb or n / nb are related to each other..
this looks like something I did in h.s. -I don't remember how I did it =[
please help
It should be: E = -13.6 ev * (1/n2 - 1/m2)
E = -13.6eV/n2
restriction:m > n
Incorrect. Should be E = -13.6 eV {(1/n2)-(1/m2)}!
1/4 - 1/3 is NOT 1/(4-3) = 1/1 !
what's the difference?
if m > n then.. ex.. if m = 3 and n = 2 ... 1/3^2 - 1/2^2 = a negative number! a negative number multiplied by -13.6 is a positive number :S
i mean, if I switch the two, won't I have to switch the restriction anyway? to make E positive? I'm confused =S
read carefully, what hikaru & kuru are pointing out.
Oh,
-13.6eV/(m2 - n2) ≠ E = -13.6 ev * (1/n2 - 1/m2)
but if m > n, then shouldn't it be
E = -13.6 ev * (1/m2 - 1/n2)
in order to get a positive energy? =S
if I put n before m i'll get a negative energy,
that doesn't make sense because photons have to have a positive energy!
I'm almost certain of that =/
Try 2:
hc/λ = -13.6 ev * (1/m2 - 1/n2)
hc/λ(-13.6eV) = (1/m2 - 1/n2)
let λ =9.50×10-8
-0.96 = (1/m2 - 1/n2)
and now..?
Ush said:
Oh,
Correct, now you see the difference.
The formula that you are using gives the change in energy of the atom. If it is positive, the atom gains energy, if it is negative it loses energy. And yes, a photon always has positive energy. You should be 100% sure of that. Take the absolute value of the difference as the energy of the photon, which could either be gained or lost by the atom.
Try 2:
let λ =9.50×10-8
and now..?
Try different pairs of integers m and n, but be systematic about it.
using different pairs of integers..
1/52 - 1/1 = -0.96
is there no mathematical way of doing this, other then guessing?
1/52 - 1/1 = -0.96
Think about it. You have one equation and two unknowns.
Of course, you can fix n and then find the shortest wavelength of a photon (highest energy) that is emitted by a transition to that level. This means that m is infinite, or 1/m2 = 0. In that case, the shortest wavelength to the n= 2 level is 2.29x10-6 m, which is much longer than 9.6x10-8 m. Any n other than 1 will give you even longer wavelengths. Therefore n must be equal to 1. Once you establish that, there is a finite number of m values that will do the job. That is what I mean by "systematic".
oh..
so giving us another wavelength in the question is just to confuse us right?
thank you for your help =)
Ush said:
oh..
I don't know, and I cannot read the mind of the person who wrote the problem. Anyway, I think you now understand how this works.
