How do I calculate energy extraction in a heat engine?
The discussion revolves around calculating energy extraction in a heat engine, particularly focusing on the theoretical and practical aspects of heat transfer between a hot source and a cold sink. Participants explore different types of heat engines, including Stirling engines and thermoelectric generators, while considering the implications of finite thermal reservoirs and efficiency calculations.
  • One participant describes a basic understanding of heat engines and requests help with calculating energy extraction using realistic parameters.
  • Another participant emphasizes that the answer depends on the specifics of the heat engine and suggests that a full understanding requires advanced study in thermodynamics.
  • A participant mentions the use of a Stirling engine or thermoelectric generator as examples of heat engines that could be analyzed.
  • One participant provides specific parameters, including temperatures and heat capacities, and asks how much energy would be extracted when a heat engine is used instead of direct heat transfer.
  • Another participant notes that the final equilibrium and energy extraction depend on the heat engine's characteristics, referencing Carnot efficiency as a theoretical maximum.
  • One participant highlights the complexity introduced by using finite reservoirs, explaining how temperature changes affect efficiency calculations.
  • There is a discussion about the maximum efficiency of heat engines, with some participants suggesting that a Stirling engine can achieve around 40% efficiency under certain conditions, while others argue that this is not the same as Carnot efficiency.
  • Questions arise regarding the energy extraction capabilities of a perfect heat engine, with references to Carnot engines and theoretical limits of energy conversion.
  • Clarifications are made about the percentage of energy that could theoretically be converted into work, with some participants suggesting nearly 3.5% of the heat flowing out of the hot reservoir could be converted.
Participants express differing views on the efficiency of heat engines and the implications of using finite versus infinite reservoirs. There is no consensus on the exact calculations or outcomes, and multiple competing perspectives remain throughout the discussion.
The discussion highlights limitations related to the assumptions made about the thermal reservoirs and the complexities introduced by finite sizes. The varying definitions of efficiency and the conditions under which different heat engines operate also contribute to the unresolved nature of the problem.
striphe
I have a qualitative understanding of a heat engine; that being that when heat moves through a heat engine from a source to a sink, an amount of energy that passes through the heat engine will be absorbed, until no heat gradient exists between the source and the sink
The attachment is a picture of a source (right side), sink (left side) and a heat engine connecting them. Can anyone show me (using their own realistic parameters) how to calculate, how much energy is extracted from the system.
Your replies will be greatly appreciated.
Science news on Phys.org
The answer to the question is entirely dependent on the particulars of how that heat engine works - you'll take entire college level thermodynamics courses to explore that question.
Something like a sterling engine or thermoelectric generator.
Please read the wiki on each of those and ask specific questions. You're basically asking us to post whole chapters of college courses.
The sink has a temp of 10C and the source has a temp of 20C. They both have a heat capacity of one kilojoule per calvin per litre. The source and sink are both one litre in size.
If these were connected together so that heat could be transferred between the two (no heat engine) I would expect that they would reach an equilibrium of 15C with 5 kilojoules moving from the source to the sink.
If i place a heat engine in the place of the medium that allows heat transfer, that doesn't involve any gas or liquid exchanges between the sink and source (e.g. a sterling engine or thermoelectric generator) What equilibrium would result and how much energy would be extracted from the system (using a realistic parameter to refer to the efficiency of that heat engine) ?
As Russ indicated, this is not a trivial problem to solve, and the origin of the problem is the fact that you made your reserviours finite.
If you had two thermal reserviours, one at 10C and the other at 20C, the maximum efficiency that can be obtained to convert heat into work is about 3.5%. If I am reading about Stirling engines correctly, the maximal efficiency is around 40%, which means your Stirling engine will convert, at best, about 1.7% of the thermal energy into work, when operating between the two (infinite) reserviours.
By making the source and sink finite, you have greatly complicated the problem, because as you draw heat from the source, its temperature changes and as you dump heat to the sink, its temperature changes also.
One way around this is to let the heat engine remove very small amounts of heat per cycle, and letting the source temperature T = T(t) and the sink temeprature T' = T'(t) as well. Then, as the engine converts heat into work, the source and sink will both approach the same temperature T_f and the efficiency of the engine approaches zero. This approach preserves the notion of equilibrium (or steady state, at least), which makes the problem easier to solve.
Going to a full non-equilibrium situation, where you attempt to withdraw the entire 10 kJ at once leads to a whole host of difficult problems: for example, how do you assign a temperature during the process?
No, a Sterling engine will do up to 40% efficiency depending on temperature difference, period: that isn't 40% of Carnot efficiency, that is Carnot efficiency for a reasonably high delta-T. So if you calculated the Carnot efficiency is 3.5% (peak) for this delta-T, then a Sterling engine will convert nearly 3.5% of the energy to work.
How much energy would a perfect heat engine to extract from the system?
Please read what has already been posted: A Carnot engine is a perfect heat engine and the overall extraction is very difficult to calculate, but the extraction would be somewhat less than 3.5%.
3.5% of the energy in the entire system?
Nearly 3.5% of the heat flowing out of the hot reservoir could be, theoretically, converted into useful work -- for the given temperatures of 10C and 20C.
  • · Replies 19 ·
9K
